TC29DA front axle gearbox filler port ?
   / TC29DA front axle gearbox filler port ? #1
TractorDale
fairfield, ct
TC 29DA
I seem to recall quite a while back that some of these came with no filler port for the front reduction gearboxes on the 4WD model. I'm changing all my fluids and can't find anywhere to put oil in except the main port on the axle itself. Did I remember correctly that some don't have these filler ports for the front gearboxes ? Thanks.
Dale
   / TC29DA front axle gearbox filler port ? #2
You remember correctly. It will take forever for the oil to drain down into the bevel gear housings. Dumb idea.
Thanks. It was slow going. When I had all the volume of 134 in for a while I opened each gearbox drain plug until clear oil flowed out. Good to go.
2019 John Deere 8295R MFWD Tractor (A50657)
2019 John Deere...
2014 Peterbilt 320 Altec AH150 Boom Truck (A49461)
2014 Peterbilt 320...
UNUSED Steel Diamond Plate (A50860)
UNUSED Steel...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
