TC40a Question? Fuel Safety Module, what is the function of this module?
   / TC40a Question? Fuel Safety Module, what is the function of this module? #1
dougobear
Skiatook, OK
New Holland TC40a
What is the purpose/job of this module? New Holland Prt#86400241, I just had this part become defective recently, It resembles a a module which plugs into the wiring harness( Little black Box) I researched the owners manual and traced the wiring schematics called the two New Holland dealerships in my area and spoke with them about it but they could not give a satisfactory answer!!!! thanks for your help
   / TC40a Question? Fuel Safety Module, what is the function of this module? #2
My Dad had an old Farmall tractor that had a 4" piece of pipe with a wire coming out of each end. He told me to never mess with it or I'd get shocked. I never messed with it until after he passed and lo and behold...It held a book of matches, rolling papers and a bag of tobacco. His one guilty pleasure, I guess and to hide it from Mom.
   / TC40a Question? Fuel Safety Module, what is the function of this module? #3
The module enables the fuel shutoff solenoid after receiving input from the key switch and various safety switches.
   / TC40a Question? Fuel Safety Module, what is the function of this module? #4
Yup.. just as the name implies.. It shuts the engine off if any of "the other" safety systems are open..
seat switch/operator present switch, low oil, overheat, neutral safety switch.. pto switch.. on & on..
   / TC40a Question? Fuel Safety Module, what is the function of this module? #5
The biggie in my opinion to have this system in working order is to shut down the engine when a low oil level issue might arise. That could save $1000’s.
Crazy stuff happens. Some examples a severe tip/rollover, a lost oil drain plug, an oil pan puncture just to name a few.
   / TC40a Question? Fuel Safety Module, what is the function of this module? #6
The biggie in my opinion to have this system in working order is to shut down the engine when a low oil level issue might arise. That could save $1000痴.
Auto shutdowns are fine on unattended equipment I would not want it on a tractor without a bypass.
Our Magnums on the farm have an auto shutdown feature but,
once activated it sounds a large beeper and a flashing indicator,
right next to it is a push button over ride.
You want to be able to overide a shutdown when working at times,
you would lose steering, hydraulic assist to the brakes, and depending on the model 4wd, clutches, ect
which could cause a major accident in which case a cratered engine may be preferable.
   / TC40a Question? Fuel Safety Module, what is the function of this module? #7
There is no factory overheat, low oil pressure or low water level shutdown on this tractor. Transmission, PTO and operator presence only.
   / TC40a Question? Fuel Safety Module, what is the function of this module? #8
any way to test the module for functionality. thanks skiboy
   / TC40a Question? Fuel Safety Module, what is the function of this module? #9
Are these what you are looking for?
  • Fuel Shutoff Solenoid Testing.pdf
  • Relay Testing.pdf
2013 FOREST RIVER WILDWOOD BUMPER PULL CAMPER (A50854)
2013 FOREST RIVER...
2011 MACK GU713 (INOPERABLE) (A50854)
2011 MACK GU713...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2019 Chevrolet Tahoe SUV (A48082)
2019 Chevrolet...
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
HUNTER SYSTEM 700 TIRE BALANCER (A50854)
HUNTER SYSTEM 700...
