The JD Cut Wheel Spacer Answer Thread
   / The JD Cut Wheel Spacer Answer Thread #61
Well, I got them done. Took about an hour. Moving these tires full of fluid was fun doing it by myself. But, I did it, and they look really good. Haven't had a reason to use it yet, but when it warms and drys up, I will be back out there. I attached some pictures. I have more if anyone wants them. One pic is of one side done and the other side not done to give you a comparison. This was as straight forward of process as anything I have ever done. The fit is very good.
:thumbsup:
   / The JD Cut Wheel Spacer Answer Thread #62
Looks good, Here is a pic of my unit with the Turf Specials.
   / The JD Cut Wheel Spacer Answer Thread #63
JD3520, Those wheels and tires don't look like mine. What is the brand of tire and the size? Thanks,
Terry,
   / The JD Cut Wheel Spacer Answer Thread #64
TCowner,
You are correct, these are not the normal tires on here, they are Michelin XMCL Steel Belted Radials. The size is just a little bit larger. The metric number for the stock size is the 400/70R20. That would equal the 42X16X20 bias tire that came on it.
My tire size is 420/75R20. I went bigger, and would NOT do it again if I had the chance. It doesn't really hurt anything, but I can't really see where it has helped either. They are a little wider, 20mm. I had to change the front tires as well to keep my ratio correct. The stock size was a 27X8.50X15. I had to step up to a 28x8.50X15. Not really a big deal, but this little tractor runs out of power rather easily without load match on, so putting the bigger tire on there didn't help in that catagory. Especially at roading speed.
The tires are far superior in traction to the stock bias tires that came on it. They have a very flat foot print, so they distribute the load more evenly across the face of the tread. And they have enough load capacity in one tire, to carry the entire tractor and loader and still have about 1,200lbs more capacity. Obviously, these are overkill on here, but with steal belts, I am not worried about flats either. They are made for a tele-handler, but work good on here as well. The fronts are Titans.
   / The JD Cut Wheel Spacer Answer Thread #65
Turned out really great. Awesome looking setup with those tires and I doubt you will have any COG/stability issues. :thumbsup:
   / The JD Cut Wheel Spacer Answer Thread #66
This is without any spacers. I am still considering getting some hub spaces and grooving my R4's lugs, and use that combo during the snow season.
   / The JD Cut Wheel Spacer Answer Thread #67
Thanks, I think it will help with stability. I don't have a lot of issues here at the house, but at the farm, there are a lot more dips and uneven places. I am hoping it helps there.
   / The JD Cut Wheel Spacer Answer Thread #68
JD3520Turbo, man that is over the top looking great! I almost wish I would damage a rear R4 so I could get those radials. Almost. I think your 3520 looked great a couple years ago with the radials on there, but now spaced out, WOW.
I guess I will have to be content with grooving my R4s.
   / The JD Cut Wheel Spacer Answer Thread #69
JDturbo, Do those tires come in a stock size? Thet look awesome.
I'd love to add 2" spacers, has anyone done that an took pics?
Matt
   / The JD Cut Wheel Spacer Answer Thread #70
They do make the 400/70R20 in this same tread design. That is the same as the stock size. I have not seen that setup with the spacers however. I have a friend that has the stock size Michelin's and he is looking at spacers. If he gets them, I will post his pictures
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A52709)
2019 KOMATSU...
New/Unused Gold Mountain 12ft x 20ft Steel Carport (A57454)
New/Unused Gold...
2012 KIA Optima Sedan (A56859)
2012 KIA Optima...
Heavy Duty Aluminum Service Truck Bed Rack (A55787)
Heavy Duty...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
