tiller leaking gear oil
   / tiller leaking gear oil #11
I have the same problem. I had a small leak. I wanted to be sure I had enough oil. Checked the manual which states fill the reservoir to just below the fill cap which I did. Now have a big leak. So I'm intrigued by the last comment that as long as there is some in the bottom, the chain will pick it up. Not much chance I'll do the "winter project" noted above.
   / tiller leaking gear oil #12
Okay, I'm not a expert on anything, but, I see some of the guys recommending corn head grease for some of the rotary cutter gear boxes, would the corn head grease be appropriate for the tiller drive cases? bjr
   / tiller leaking gear oil #13
My tiller has done the same and I probably filed it to much. It does seemed to have slowed though probably due to less oil. Was thinking about the heavier oil. It does have some in it so I will mo it or usage and see were that goes
2016 Ford SD Dump Truck (A52377)
2016 Ford SD Dump...
2015 Ford F-250 Liberator 3200 1.5 Ton Crane Service Truck (A55852)
2015 Ford F-250...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
