Tire Wobble
   / Tire Wobble #11
On hard surfaces, with ag tires, you can often get a wobble, or kind of like a shimmy, from the lugs on the R1 tires. This was one of the main reasons that R4 (industrial) tread became popular on CUTs.
If lugs are tight, no run-out in rims, steering components seem ok, and unit only does it on hard surface, i.e. concrete or asphalt, I wouldn't worry about it too much.
To check this out, go to a dealer, and "test" drive a brand new unit with ag tires, on asphalt, or concrete. Even at low speed you will be able to detect a "wobble" as you move forward.
   / Tire Wobble #12
Jerome:
If you have R-1's the tires themselves could be the culpret. Driving on hard surfaces in 4WD may also be a factor. I get "wobble" when I travel on the highway. It is worse at "higher" speeds. Use your flashers and lights and show your SMV emblem on the highway! Jay
   / Tire Wobble #13
Jerome said:
I took my Kubota L245DT on the road yesterday and at on point I had significant tire wobble this has not happened before. Was I just going at the certain speed to make the lugs on the tires do this or should I be worried? When I slowed down it stopped.
Just last month I got a call from my neighbor who needed the help of my TC-40D and pallet forks. Seems he was out raking hay when the left rear wheel on his TN70D rig came off. I'm not sure how it got so lose without some warning but nevertheless it still came off. Must have been a real ride as the tractor started down. :eek: Check your lug nuts guys!
   / Tire Wobble #14
could be a bent rim. either way if everything is tight, at 10 mph I would worry. it'll just keep you awake.
   / Tire Wobble #15
I voting with you, flat spots on tires due to sitting. As it gets colder, you'll notice it more. I moved my tractor to a friends a short time back on a cold morning. I felt the bounce. Sure enough I could see the out of round in the tire. By the end of the 20 min ride, it was much less noticable.
Original poster;
For a hoot, next time you park your tractor, mark the inside of the tire just infront of the fender. As you drive you will likely feel the bounce/see your mark at the same time.
   / Tire Wobble #16
My tractor does not have radial tires. Bias tires will have flat spots until you move. I notice this more often when it gets colder as mentioned.
   / Tire Wobble #17
Jack the front end up and spin each wheel, looking for a lump on the tread, indicating a broken belt in either tire. That causes what they call "low speed wobble" in cars. On tractors, low speed is all you got.
   / Tire Wobble
I tracked the problem down to the angled lugs on the front tires coming into sync when the tires were both rolling over the left facing lug at the same time it would push the tire that way then right on the next lug. It is easily corrected by making a slight turn to take them out of sync
   / Tire Wobble #19
Jerome:
Now that I think about my road travel, I think you are right. Jay
Unused 2025 CFG Industrial MH12R Mini Excavator (A59228)
Unused 2025 CFG...
2017 Scag Cheetah 61in Zero Turn Commercial Mower (A59228)
2017 Scag Cheetah...
NEW Thiessen Track Closer Disk (A56438)
NEW Thiessen Track...
CASE 610 Sprayer System 2000 Gallons (A56438)
CASE 610 Sprayer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Unverferth Road Runner Head Cart (A59814)
Unverferth Road...
