TN95A clutch broke.
   / TN95A clutch broke. #11
Did you find out what was wrong?
I have not split it yet.
My son bought some property and has required my help.
I hope to get to it this weekend.
Thanks for asking. I will let you know as I know.
I split it Thu/Fri.
Can you say Murphy's law? Anything and everything that could go wrong did, but I got it apart.
I have never dealt with a two stage clutch before. I had a hard time figuring out how to get the throw out bearings out.
The first bearing was frozen up and had a part of the bearing cage sticking out. I thought it would all be gone due to the lack of pedal pressure. Due to it not spinning, it killed the pressure plate fingers.
I bought the whole clutch kit. I did not think I was bending over when I walked in but, I guess they did, so they stuck it to me for close to $1500. If I knew what I was doing, I would have shopped around.
They did not have the alignment tool. I am not sure how I am going to get the clutch plate in the right spot. That is just one problem.
The first and bigger problem is the pilot bearing. It felt ruff so I am going to replace it. On cars, I have always filled the hole with grease and put a hole size bolt in it, and hit the bolt with a hammer. The pressure on the grease would drive the bearing out of the crankshaft. This did not work. I am guessing the inter seal was gone because the grease went though the bearings and out past the front seal. Don't know what I am going to do now.
Any Ideas?
At this point I think I am going to try a slide hammer. Then maybe destroying the inter race and bearing cage to where just the outside race is there. At which point I will try the slide hammer again. Then maybe a drimmel tool, cutting it to where I can get it to fracture. Or maybe putting a weld bead on half of the race.
Next question, The longer inside transmission shaft came out about a foot when I split the tractor. I pulled it out about 2 more feet, thinking I could use it for the alignment tool. Then I wondered if there were gears on the shaft that would or did fall off when I pulled it so far out.
Can anyone help me on this?
Thanks to "Harry in Ky" for his PM in response to my request for help.
   / TN95A clutch broke. #15
Harry is truly awesome. I run a couple of New Hollands and I've come to depend on his judgment for anything related to either of them. I do a little bit of work on them myself, but let my dealer do the big jobs. I have a lot of trust in the techs and the service manager at my dealership, but I always get a second opinion from Harry. I'd hate to imagine running tractors without him. He's a great asset, both to me and to this site, and just one more thing that makes tractorbynet an essential bookmark.
   / TN95A clutch broke. #16
Thanks for the kind words guys. I'm glad I was able to be of help.
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
CHAINSAW BENCH GRINDER (A58374)
CHAINSAW BENCH...
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
2018 TowMaster T-12D T/A Flatbed Trailer (A55853)
2018 TowMaster...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A58017)
2012 INTERNATIONAL...
PALLET OF MISC (A58374)
PALLET OF MISC...
