Too many AMPS ? break-away emergency switch thru deep cycle battery
   / Too many AMPS ? break-away emergency switch thru deep cycle battery #1
TimBuck2
Central Massachusetts
Kubota L4310 HST and Ford 841
I am rewiring a 10K trailer, with electric brakes at all four wheels.
The break-away switch was wired though typical small "Universal" battery that is dead, and the box it was in is caput.
The previous owner added a winch, for which the trailer carries a deep cycle battery. I would rather not have to worry about maintaining two batteries on the trailer.
Is there any reason I can't wire the break-away switch through the deep cycle battery? (aside, or course that I will need to make sure there is a live battery on-board when being towed).
Is there a resistor in the normal brake activation circuit?
My only though is - too many Amps might fry the brakes and/or wires to the brakes.
Thanks,
Tim
   / Too many AMPS ? break-away emergency switch thru deep cycle battery #2
That is how my camper is wired, 12 volt deep cycle battery only.
   / Too many AMPS ? break-away emergency switch thru deep cycle battery #3
Thanks,
Tim
Remember.. the brake controller normally is what powers the e-brakes.
during an emergency where the break away becomes active, all it is doing it making bat hot and brake power common.
The brakes will be their own self limiting electrical load. If you left them like that all day. yeah.. I'm sure soemthing would get hot. :) Generally worrying about the brake magnets long term lifespan is the LEAST of your concerns when you look back and your trailer is NO LONGER behind your vehicle!!!
   / Too many AMPS ? break-away emergency switch thru deep cycle battery #4
No reason to have 2 batteries, every camper in the world is wired that way and they've been doing it that way for 40+ years at least. I know our 1978 camper was wired that way.
   / Too many AMPS ? break-away emergency switch thru deep cycle battery #5
Remember that the load determines the amps. The brakes will only "draw" as much current as they need. It's Ohm's Law. I = V / R. For example, a 10-inch brake magnet might have a resistance of 3.5 ohms. At 12 volts, it will pull 12 / 3.5 = 3.4 amps. This will always be true, no matter how big the battery is or how many amps it is capable of supplying, as long as the battery is putting out 12 volts.
Thanks for the input gentlemen.
Tim
   / Too many AMPS ? break-away emergency switch thru deep cycle battery #7
Exactly.. load determines amps based on a capable voltage source.
   / Too many AMPS ? break-away emergency switch thru deep cycle battery #8
Campers and dump trailers usually use the deep cycle. No issue what so ever.
Chris
2004 Saturn VUE SUV (A55853)
2004 Saturn VUE...
2016 Ford F-150 Pickup Truck (A55852)
2016 Ford F-150...
1000 GALLON PORTABLE POLY PUMP TANK (A57192)
1000 GALLON...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
2018 Chevrolet Equinox SUV (A56859)
2018 Chevrolet...
