Towing Three Balers Behind One Tractor
Robert_in_NY
Super Member
Silver Creek, NY
Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
The idea might work if you could have everything work off of a gps system so the balers would follow the rake swaths on their own. However, if one baler breaks down then you have two other balers parked as a result. Unless you are short handed for labor it would seem like a better idea to have three tractors just incase a baler breaks down the other two will keep running.
   #12
Chuck_Lind
Mahaffey, Pa.
2000 New Holland TN65 & 1956 John Deere 50
Mickey_Fx said:
From the looks of the pics, this set-up is being used in an area where yields are low. Up in this neck of the woods, no way would this set-up work. I've seen 125HP tractors struggling to handle the load when bailing timothy. This was using HD freeman sq bailers. They can eat a hellofa lot of hay and you'll see some with a wheel rake at the mouth to help gather up the windrows.
This operator has to be busier than a one legged man in a butt kicking contest trying to keep these 3 bailers lined up.
Interesting pics.
I'd say the operator of that tractor would be "busier than a long-tailed cat in a roomful of rocking chairs".
   #13
Bob_Young
Veteran Member
North of the Fingerlakes - NY
Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
If it really was a low yield area, you'd think they'd be better off using a merger, something like a Miller Avalanche. Getting 3 or even 5 rows into one would be no trick. Then follow up with a high capacity baler. The spacing seems to indicate a two-into-one windrow
And moving an Avalanche from field to field would be a lot easier than that setup.
Are those hydraulic motors spinning the flywheels? Bet they have to bring them online one at a time.
Bob
   #14
AndyMA
Elite Member
Windham County, Conn
Ford 2120 , Kubota MX5200 , Deere X748SE. 1956 Economy Tractor
No I've never seen it. and BTW, no I don't want to drive it except in a straight line. It certainly wouldn't work in our small New England fields with lots of rocks.
Andy
   #15
jimg
Veteran Member
I strongly suspect this setup only plays well in the W/midW where its relatively flat and fields are very large. I think most inlines are used there b/c Ive seen very few here and most of those on the used market are from there.
   #16
scott_vt
Super Member
east wells,vt
1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
Grrrr said:
I was thinking you were going to need to be pretty accurate with raking to keep the rows all equidistant apart. (Unless each baler can be moved sideways to follow the windrow.
Mornin Jake,
To me that would be one of the most challenging parts of that operation ! ;)
Mornin Robert,
This fella must have a lot of confidence in his preventive maintainance program ! :)
   #17
JESSE1
Veteran Member
Kilgore, Texas
JD 6400
I saw a picture once of a tractor pulling a hydraulic v-rake and had a round baler hooked to the rake. Driveshaft ran from tractor up and over the rake to the baler.
   #18
Spiveyman
Platinum Member
Central KY
Ford 6610 II
The real trick would be to have 3 hay wagons hooked up following the balers. :eek: I'd hate to have to go back and pick up all those dang bales! Must be a low yield area, look how spread out the bales are.
   #20
civesnedfield
Platinum Member
Central Maine
2007 Mahindra 4530----1972 Massey Ferguson 1100
Andy
I agree Andy. Up where I am at, if a hay field doesn't have at least 7 corners, it's not worth it. :D
