Snow Tractor blows smoke and bogs down
   / Tractor blows smoke and bogs down #1
MontanaBoz
B2650
I have a B2650 with a front end B2782b snowblower both with 80 hours. My tractor runs fine but blows black smoke and bogs down when using the snowblower. I've tried going slower but at WOT and it happens even with minimal snow. In general, tractor seems to feel underpowered.
What's the cause and more importantly, how do I fix this?
I suspect:
1. Water in fuel?
2. Blocked air element (I've changed air filter)
3. Fuel filter needs replacement?
4. I've greased the chain and zerks etc
Thanks for your help!
   / Tractor blows smoke and bogs down #2
Black smoke is unburnt fuel. I would not think its fuel related.
   / Tractor blows smoke and bogs down #3
Guessing you have a DPF? Is it clogged, have you done a regen at all?
My guess too. Not sure where to go from here though. Any recommendations? Thanks!
I thought of that too. My tractor does not have an automatic regen. Can I do it manually?
Thanks! Wasn't sure about DEF. Could there be water in the fuel...if so how do I get rid of. Winter blend fuel.
   / Tractor blows smoke and bogs down #8
Add some diesel additive increase RPM's little more.
Any suggestions which is 'best' for winter use? Thanks!
   / Tractor blows smoke and bogs down #10
This may prove helpful: DIY diesel problem diagnosis | Dog And Lemon.
Power Service and Howes are two of the more popular diesel fuel additive makers. Each company makes a variety of additives for specific needs like cetane boosting, anti-gelling, water removing, alge-scum removing, fuel stabilizing, etc.
Having a fuel-water separating filter helps manage the water.
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A50860)
2012 Big Tex T/A...
Vermeer SC802 (A50322)
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A51039)
Adams Load Out...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
