MinnesotaMorg
Looking for updated opinions on what snowblower I should get. I previously got a MK Martin 87, but things happened and I ended up trading the 4707 before I even had a chance to use the snowblower.
I now either need to get a 8' PTO snowblower, or get a hydraulic snowblower for the skid. I initially was just going to get another PTO snowblower, but looking at the prices for 96" or 108" wide pto blowers the price is reaching the same as a hydraulic from Erskine/QuickAttach. So while previously the price of hydraulic made it prohibitive to consider, now if I'm going to be dropping upwards of 7k I just want to go with what is going to make my life easiest. I should add that I have heard that sometimes people get blowers for their skids and they are underwhelmed by the performance, but that is because they purchase a blower that doesn't match their flow rate very well. The blower I'm considering for the skid they ask what machine you're putting it on to match the hydraulic motor as best as they can.
Here is what I've seemed to gather so far
PTO specs: 96" width, 43" height, dual auger, impeller diameter 32"
PTO advantages: No motors, theoretically should be easier to maintain (chain,lube,shearpins), slightly cheaper even at 96/108", larger overall, larger cut height, impeller
Skid specs: 79" width, 36" height, single auger, impeller diameter 24"
Skid advantages: Easier to hook up, won't have to disconnect blower from tractor if I need to haul hay, front facing, more maneuverable, hydraulic pressure (no shear pins)
The new tractor is CVT, so it's almost as nice as the skid to drive while blowing, but it's also a bear in comparison, so getting into tighter spots will be more challenging or impossible. Is there anything I'm missing? I need to make a decision this week as it's already snowing.
