Never touch the 3rd rail.A lot of states have similar politics when there is a large city, in the case of Illinois it’s Chicago.
Helped a neighbor across the lake take down some trees and he didn't want any of the logs! View attachment 756177
If you remember in an earlier post, I had to get some steering cylinder hoses made for my tractor. The rest of the story is, one end of the hose needed to be a "banjo" fitting, and NO one anywhere around here can make those! I called all over and it was a no-go everywhere!
One hydraulic shop suggested I convert it to a more common fitting, so I agreed,
The problem with that was, too many joints, that come loose too easily and then would leak! On top of that, it sets the hose up too high and then the leverage on the fittings, slightly bends them, and they leak!! I was on a job when I figured all of THAT out!
SO, after looking it all over better, off I go to a welding/hydraulic shop I know of, and I KNOW they do really good work. I suggested to them, that they saw the banjo fitting off the old hose, and tig weld it onto something more common and make me another hose! The guy thought about it for a moment and said, "that should work!"
You can see the weld in this pict.,
Anyway, fifty dollars later and I have a hose that sets on the cylinder low, stays tight without leaks, and stays that way!
SO, off I went to a job to cut out a bunch of pines,
some were 5" across, and I took out a bunch of them! AND I managed to put a little more coin in the till! lol
SR
What I don't understand (about myself) is that from that entire post the first thing which my eye caught was "Banjo", and I suddenly had flashbacks to a certain movie.Great solution on that hose SR
gg
Some things just leave a lasting impression I guess...What I don't understand (about myself) is that from that entire post the first thing which my eye caught was "Banjo", and I suddenly had flashbacks to a certain movie.
Aint he got a purty mouth?What I don't understand (about myself) is that from that entire post the first thing which my eye caught was "Banjo", and I suddenly had flashbacks to a certain movie.
You might look through the Parker catalog seems like if I remember right they make that sort of fitting. Another way to do it is a straight jic out of the cylinder to a short neck 90 on the hose would also be a smaller lift then the 90 male female union they added. Another option is a screw in 90 then the straight jic on the hose.If you remember in an earlier post, I had to get some steering cylinder hoses made for my tractor. The rest of the story is, one end of the hose needed to be a "banjo" fitting, and NO one anywhere around here can make those! I called all over and it was a no-go everywhere!
Anyway, fifty dollars later and I have a hose that sets low on the cylinder, stays tight without leaks, and stays that way!
SR
I could have ordered the line from AGCO, but that takes time, same as ordering one through a catalog. Then there's making sure you get the right one too...You might look through the Parker catalog seems like if I remember right they make that sort of fitting.
