Transporting a bush hog
   / Transporting a bush hog #1
ironpen
Montgomery, Alabama
tn75s, tc33d, mc35, gt65, 6640, 3010s, TS110, TS115, TN70, Massey 5470, Kubota F2690
I need to move a bush hog about 30 miles. It is 110 inches wide and weighs 1600 pounds. Any ideas on how I could get it moved?? I am really stumped!! It does not have pneumatic tires. It has a hydraulic lift on the back tires...i.e. it is not a three point attachment.
   / Transporting a bush hog #2
Is there anyway you could load it on a trailer. If you could get two tractors you could lift it up then back under it.
   / Transporting a bush hog #3
Does it have the rubber composite tires or foamed aircraft tires, ours has the aircraft type and was towed behind a pickup about sixty miles when it was delivered.
   / Transporting a bush hog #4
Set it on a trailer with a front end loader, boom it down and take off.
I'm guessing it's wider than it is long, turn it sideways on the trailer. Or just pull it with the tractor, shouldn't take more than 2-3 hours.
   / Transporting a bush hog #5
Rollback wrecker. Pull it up side ways with the winch, remove tongue and pto shaft.
I has rubber composite tires. My front end loader MIGHT pick it up.....but there is no FEL Where it's going. If I used the rollback wrecker...how would I get it off at the destination??
   / Transporting a bush hog #7
Gravity, winch has power out too. Raise bed up and lower it back down with the winch.
   / Transporting a bush hog #8
Or, do like I've done before... get a tow strap (or chain) and attach one end to a tree, the other end to the bush hog and have the driver drive forward slowly as the bush hog slides off the flat bed wrecker (with the bed angled down, of course, and just barely above the ground).
   / Transporting a bush hog #9
Compare the price of new tires vs roll back then go from there.
   / Transporting a bush hog #10
Personally I would hire a roll back. I just bought a 4610 Ford tractor and had it hauled 120 miles round trip for around $1.50 per mile. That's cheaper than me getting a trailer to haul it plus the liability, possibility of break down, ETC...In my mind it is not worth it. I did haul a 6' bush hog on a loaned trailer 320 miles round trip. Got along fine but you never know when some nut is gonna cut off in front of you or the possibility of a blown tire. It happens.
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
Swamp Buggy (A49346)
2010 Pontiac G6 Sedan (A48082)
2010 Pontiac G6...
LOT LOCATIONS (A51222)
AFE SSMM Disc Mulcher Skid Steer Attachment (A49461)
AFE SSMM Disc...
2013 Chevrolet Impala Sedan (A48082)
2013 Chevrolet...
