s219
Super Member
- Joined
- Dec 7, 2011
- Messages
- 8,608
- Location
- Virginia USA
- Tractor
- Kubota L3200, Deere X380, Kubota RTV-X
Anybody have a good solution for a trench or channel drain across a gravel (crusher run) driveway? Right now I have a very shallow swale in the driveway in front of my barn door, which helps divert water that flows down the driveway towards the barn. Works well, but I have to scrape it out periodically since it fills with pine needles, loose gravel, dirt/mud from tractor tires, etc. Over time, the swale tends to fill and flatten back out.
I was thinking about putting in one of those pre-fab channel drains, but they are plastic with a sheet-metal top grate, and I don't think they would hold up under the tractor tires for an extended time. And the grate openings are pretty small, so I suspect gravel will plug them up.
The cleverest solution I saw was recommended by the US Forest Service -- they use metal guardrail (which has a sort of flat "W" shape) bedded down into the gravel to make a permanent swale that is easy to scrape out. Unfortunately I haven't found a way to buy guardrail around here. Another solution I have seen is to dig down some treated 4x4 timbers with a gap between them to act like a channel.
