Troubleshooting Gutless Dodge 2500
   / Troubleshooting Gutless Dodge 2500
Rockauto.com
Direct fit with Y pipe $192
Only problem is that it's over $200 to do "international economy" shipping to my postal code in Canada! :laughing:
I would be spraying down all the bolts and or nuts now with a penatrating spray of some kind before you start this job it may help them come loose easier! :thumbsup:
For sure! I have some Liquid Wrench that I used on the O2 sensor nut. Seemed to work pretty well. Failing that, can a guy use impact gear on this stuff? I have a full set for it if I can get the wrench in there. Probably too tight.​
   / Troubleshooting Gutless Dodge 2500 #63
PB-Blaster works good too.:thumbsup:
   / Troubleshooting Gutless Dodge 2500 #64
I have found:
- the easier it is to get to a nut/bolt with my impact sockets/gun, the less likely it is to break and require drilling, tapping, or complete replacement
- The harder it is to reach my impact gun and sockets in to the more likely it is to break things that are hard to drill, tap, bandage...
Otherwise, I love my impact gun and sockets :D
   / Troubleshooting Gutless Dodge 2500 #65
Amen. I replaced the outlet pipes on a vehicle a lot newer than the OPs. 4 bolts, how hard can it be? I sprayed the bolts the night before and used an impact gun. Added heat. The bolts would not budge. The local muffler shop had to use a cutting torch to get the 2 joints apart. They also had the gaskets needed. Charged $60. Worth every penny.
On my 1st and 3rd car I replaced the exhaust myself. This is back in the days when you went to the parts store and got everything pre-bent. Took me 6 hours on the first and it always leaked. Cost about $100 back then for everything. On car #2 I had it replaced at Midas for $125. Then I got stupid on car #3 and thought I would do it myself. Again, all day and never was quite rite. I also decided to replace the shocks on that one. Got the shocks for about $60 and replace the rears in 10 minutes. The fronts took 10 hours, a few trips to the store, ect. Never again. If I would have had a torch and not trying to do it after work I would have gotten them off in 10 minutes each also. Just out of curiosity I went back to the same Midas and they would have done them for something like $30 more than I paid for the parts.
Live and learn.
Chris
   / Troubleshooting Gutless Dodge 2500 #66
Pretty clean looking truck, good luck getting it fixed. It sounds like you are getting lots of good advice. I've done exhaust work and had it go easy, and also had problems. If the system isn't in that good of shape, its usually easiest to get the entire thing fixed.
Quick update. I took the advice and did some phoning to see what local muffler shops would charge to replace the catalytic converter. A couple of them will do it for $320-340 by welding in a universal cat.
Since the direct connect OEM type was $350 for me to purchase plus I'd have to deal with actually putting it in...I'm leaning towards that route.
Any reason why a universal (Magnaflow) shouldn't be put in?
Thanks.​
   / Troubleshooting Gutless Dodge 2500 #68
As long as the rest of the pipes are in good shape i think that would be a good option. you don't want them welding to pipe that is going to rust off in a month.
   / Troubleshooting Gutless Dodge 2500 #69
Like I said before, I would let the muffler shop do it.
Chris
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PALLET OF GOLF CLUBS & MISC (A58374)
PALLET OF GOLF...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56435)
2002 Chevrolet...
2009 FREIGHTLINER M2106 26FT BOX TRUCK (A58017)
2009 FREIGHTLINER...
FRONT BLADE (A52708)
(2) SECTIONS OF 42" W X 8' L X 9' H PALLET RACKING (A58374)
(2) SECTIONS OF...
