try again re kubota b7100D fel
   / try again re kubota b7100D fel #1
doktorslo
anyone know how to change or tighten the front belt that runs the hydraulic pump for the fel?
   / try again re kubota b7100D fel #2
A picture maybe? My B7100 runs the FEL off the tractor hydraulics - no external pump...
/Kevin
   / try again re kubota b7100D fel #3
   / try again re kubota b7100D fel #4
The ones I've seen with a front pump use a chain coupler between crank and pump.
thanks u guys-----i typed that thread in too much of a hurry----yes, the pump is linked to the crankshaft which runs the fan belt. it looks as if to change the belt, i've got to pull the pump and the front of the tractor,and the radiator!!! this cant be right. doesn't look like there's any way to tighten the belt?!
   / try again re kubota b7100D fel #6
If you are changing fan belt, yes, you will have to disconnect hyd pump. You should NOT have to remove radiator and there should be a tensioner pulley above the oil filter.
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
71066 (A49346)
71066 (A49346)
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
