Underground hose extension
   / Underground hose extension #11
I think there may be codes about sewer and water in the same trench, especially about water UNDER sewer lines.
If there was ever a problem with the septic line AND the water line (pretty big odds I think) you could end up siphoning back into your house.
With that said, I would run a water under septic and put in a check valve at the point I tied in the branch line. You could even place some concrete extending a few feet on either side of the septic line for additional insurance.
I'll be running hose bibs to the horse troughs and will install a check valve in the pump house cause I know the wife is gonna leave the hose in the trough. /forums/images/graemlins/shocked.gif
   / Underground hose extension #12
A few years ago, in our area, I learned that you could run a waste water or sewer line under a water line, but if you went over a water line, the waste water line had to be encased for 10' on either side of the water line.
   / Underground hose extension #13
I used a middle buster or a subsoiler connected to a curved iron pipe to bury a black flexible pipe about six inches in the soil. It worked very well. I got the idea off a thread in TBN posted several years ago.
Tried to find it; maybe someone else knows the right keywords. There are photos in the thread.
   / Underground hose extension #14
A few years ago, I extended a water line out to a new shed about 200 feet from the closest spigot. I ran 1 1/2" black well line. At the house side, I connected a coupler that then has a hose connector screwed in. I then made up a short length of garden hose about 8" with female ends on both. This allows me to connect to a 2 way brass splitter at the spigot and allows some fexibility when connecting the line for the season. At the shed side, I made up a connector that has a coupler, then a 6" length of pipe, then a air hose connector, another 6' pipe and than a boiler spigot. I fatened this to a piece of pressure treated wood that I fastened to the side of the shed. If I had a digital camera I would post pictures, sorry!
Around the end of November, I disconnect the lower end at the house and blow air through the line using the air fitting and a normal compressor. Blows the line out in 1-2 minutes, and I don't worry about any freezing. The line is only 8" deep. Works very nicely for me and only cost about $25 in plumbing fittings. I plan to run a similar line this summer out the front of the house to my orchard.
Good Luck!
Big Eddy,
That was my original "plan", but I was afraid that the water inside the hose would freeze and burst the hose. Maybe I'm worried for no good reason.
Thanks
That's exactly what I want to do.
Thanks for the description!
   / Underground hose extension #17
   / Underground hose extension #18
Here's a photo of the blowout hose I made. The left end is a quick connect and works like any air tool with my compressor quick connect fitting. The right end works just like a garden hose and will connect to any standard faucet fixture.
   / Underground hose extension #19
Closeup of connector to air compressor.
   / Underground hose extension #20
Closeup of connection to plumbing line.
71055 (A49346)
71055 (A49346)
2000 Coachmen Mirada 340MB Class A Motorhome (A48082)
2000 Coachmen...
UNUSED 20PCS 2in. Polyester Lifting Strap (A50860)
UNUSED 20PCS 2in...
Wacker Neuson TH522 Telehandler (A50860)
Wacker Neuson...
1994 LUFKIN (A50854)
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
