Using the QUOTE feature
   / Using the QUOTE feature #1
Gatorboy
Elite Member
Bel Air, MD
Kubota M8950, Bobcat 873 SSL & Kubota ZD-331
Just an observation and suggestion:
I don't know if this is something that some of guys haven't learned yet, or maybe they're just not taking the time to do it. But when you want to quote someone else, it's an easy thing to do to hit the "quote" button. Then you can highlight any and all words that don't need quoting and you can hit the delete button to take them out. In this way, you can pick out just the part of someone else's post that you want to address without totally repeating everything that that person has said. This is especially true with long posts and you're the very first person to reply. There isn't any point in going through a long post twice. It really makes your reply quicker and easier to read if you'll just spend a few seconds editing out what is unnecessary to make your point.
   / Using the QUOTE feature #2
</font><font color="blue" class="small">( But when you want to quote someone else, it's an easy thing to do to hit the "quote" button. Then you can highlight any and all words that don't need quoting and you can hit the delete button to take them out. In this way, you can pick out just the part of someone else's post that you want to address without totally repeating everything that that person has said )</font>
Like this Dave? I've never used it myself. I use the blue color tags but the quote seems to work the same. Thanks for the tip /forums/images/graemlins/smile.gif
   / Using the QUOTE feature #3
</font><font color="blueclass=small">( I don't know if this is something that some of guys haven't learned yet, or maybe they're just not taking the time to do it. But when you want to quote someone else, it's an easy thing to do to hit the "quote" button. Then you can highlight any and all words that don't need quoting and you can hit the delete button to take them out. In this way, you can pick out just the part of someone else's post that you want to address without totally repeating everything that that person has said. This is especially true with long posts and you're the very first person to reply. There isn't any point in going through a long post twice. It really makes your reply quicker and easier to read if you'll just spend a few seconds editing out what is unnecessary to make your point. )</font>
I used to use it, but then if you go in and edit anything in your post, everything ends up looking like this! /forums/images/graemlins/confused.gif
I've found it's easier to use a blue font color and put my quote inside that. Then, if I have to go back in and edit my post for any reason, my nice blue quotes don't turn red.
<font color="blue"> ( I've found it's easier to use a blue font color and put my quote inside that. ) </font>
How you end up quoting doesn't matter, the point is not to "quote" the entire post, only the sentence or two that applies to your response.
</font><font color="blue" class="small">( I used to use it, but then if you go in and edit anything in your post, everything ends up looking like this! )</font>
If you edit a post that used the {quote} tags, you have to enter them back in manually, otherwise you get what you have shown. Using the blue font is probably the better way, for it will edit properly without any extra edits.
   / Using the QUOTE feature #6
<font color="blue"> If you edit a post that used the {quote} tags, you have to enter them back in manually, otherwise you get what you have shown. Using the blue font is the best, for it will edit properly without any extra edits. </font>
That's why I use the blue font instead of the quote feature.
It saves me from the extra effort of re-entering the quote tags manually if I have to edit my post for any reason. /forums/images/graemlins/smirk.gif
<font color="blue"> ( That's why I use the blue font instead of the quote feature. ) </font>
Now, if you can just NOT quote the entire post you are responding too (like you have done in the two quotes in this thread). /forums/images/graemlins/grin.gif
   / Using the QUOTE feature #8
Sometimes when you selectively quote, you can change the meaning. So, it's a good practice to indicate that words have been left out. Good gramar suggests the use of ellipsis marks -- a series of 3 periods. For example:
<font color="blue"> ...if you can...post...two quotes in this thread... </font>
In the electronic messaging world, the use of {snip} is also gaining popularity:
<font color="blue">{snip} quote the entire post {snip}</font>
Maybe we need an emoticon that looks like
The important thing is to indicate in some manner that you have not quoted the entire message.
   / Using the QUOTE feature #9
</font><font color="blue" class="small">( Sometimes when you selectively quote, you can change the meaning. So, it's a good practice to indicate that words have been left out . . . )</font>
I usually trim my quotes, but I have failed to indicate that I have done so. A very good point, OkeeDon. Thanks for the reminder.
Cliff
   / Using the QUOTE feature #10
</font><font color="blueclass=small">( </font><font color="blueclass=small">( I don't know if this is something that some of guys haven't learned yet, or maybe they're just not taking the time to do it. But when you want to quote someone else, it's an easy thing to do to hit the "quote" button. Then you can highlight any and all words that don't need quoting and you can hit the delete button to take them out. In this way, you can pick out just the part of someone else's post that you want to address without totally repeating everything that that person has said. This is especially true with long posts and you're the very first person to reply. There isn't any point in going through a long post twice. It really makes your reply quicker and easier to read if you'll just spend a few seconds editing out what is unnecessary to make your point. )</font>
I've found it's easier to use a blue font color and put my quote inside that. Then, if I have to go back in and edit my post for any reason, my nice blue quotes don't turn red. )</font>
Sorry, couldn't help it had to find out what would happen if I quoted one of those edited post quotes then edited it myself. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Mike
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
2013 Ver-Mac Solar S/A Towable Trailer Message Board (A49461)
2013 Ver-Mac Solar...
2021 Snake River 14K Dump Trailer (A49461)
2021 Snake River...
2012 John Deere 9560RT Track Tractor (A50657)
2012 John Deere...
2014 PJ 24+6 T/A GOOSENECK (A50854)
2014 PJ 24+6 T/A...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A51039)
2024 BCL...
