Very Weird Noise, Need Help!
   / Very Weird Noise, Need Help! #11
With the exception of the engine model, I'm pretty sure my '96 Cub Cadet 7274 is the same Mitsubishi built tractor as your Mahindra 2816. In 2000 hours, I have never had any issue like you described.
...is something breaking loose in the clutch assembly???
After the way this issue started, your guess seems as good as any. If the clutch is the same as my Cub Cadet, it is a two stage, fully depressed activates the PTO clutch.
...a popping/grinding noise starts and I'm not even pressing the clutch. You could tell that it effected the engine RPM. I immediatetly stopped and put in neutral and it quit.
Were you in 4WD? Was the noise right under your feet or could it have come from the front end? I have broken parts in the front drive swivel joints and had noises like that.
Well I dropped her off at the dealer this morning. The mechanic listened to it for a bit, it was rubbing/squealing/knocking and all, he was like yep, sounds like the throw bearing, pilot bearing and clutch is all messing up, He acted confident about the warrantly coverage and said they would get it taken care of. Made me feel alot better about the situation. We'll just wait and see what they find out.. Thanks for all the replys.
   / Very Weird Noise, Need Help! #13
Be sure to let us know the outcome.
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
2015 Hamm H7i VR-3 Single Drum Vibratory Soil Compactor (A49346)
2015 Hamm H7i VR-3...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
2015 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
