Wanted , Arm Restright side tl100a
   / Wanted , Arm Restright side tl100a #1
M5farms
Platinum Member
Panhandle
jd 2630 - NH TL100A-35 ferg-53 ford backhoe
seat no longer available , It seem these arm rest are like hunting hens teeth. what im looking for would be an original but will settle for just one I can adapt. It seems that ones off of ZT mowers are the closet design . and Im not opposed to paying a fair price but If I have to manufacture something I prefer not to cut up a new one. It just slides on a pin and threaded pin screws into the back and acts as a stop.
SO I guess no one has one laying around so Saturday I decided to build one I took the left one off for a pattern glued two 2x 6s together and cut it out bored a 1" hole and a slot in the back . I had to take it on and off several times to take a little more off the back slot so the angle would be right but it works fine. I was going to put a layer of neoprene on the top and then dip it in plastic dip but some body left the lid off and it was hard so I just did a red neck upholstery job with an old wet suit and it will work.
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2008 JACK COUNTY  130BBL VACUUM TRAILER (A50854)
2008 JACK COUNTY...
2018 Ford F-150 (A51039)
2018 Ford F-150...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2018 VOLVO VNL...
Lot of 4 Dell Laptops (A48083)
Lot of 4 Dell...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
