Ballast Water Ballast in Tyres
   / Water Ballast in Tyres
If that tire is old, brittle, and now has torn cords,
You might want to get a ROPS next.
Yeh the tyres are old and brittle.still the original Farm Service Lugs(Rice Paddles) and i do already have a ROPS-not allowed to run it in Australia without one.
Huge Improvement on sideslope,traction and also it does not buck around anywhere as much as it did without water ballast. only thing i noticed it requires more throttle now and the clutch has to work a bit harder. apart from that i am happy.
   / Water Ballast in Tyres #23
Just something about the angle in the picture makes me pucker........
   / Water Ballast in Tyres #24
Here in Oregon it does get cold in the winter, so we use antifreeze & water for the tires.
We save our old antifreeze that we drain from the tractors, and we also buy it from a radiator shop nearby.
We put about 3 gallons of antifreeze per tire on a 1610 =8.3-22 size.
We found that calsium will destroy the rim if the inner tube develops a hole inside, not to mention the damage to the valve stem.
Ernie
2019 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A52709)
2019 CATERPILLAR...
2013 RAM 3500 FLATBED (A58214)
2013 RAM 3500...
FUEL PUMP W/NOZZLE (A58216)
FUEL PUMP W/NOZZLE...
2111 (A58376)
2111 (A58376)
2011 GROVE TMS900E TRUCK CRANE (A58216)
2011 GROVE TMS900E...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
