I forgot about that. 8 years ago. That (hacked) roller is in a steel pile 125 miles away, under 18” of snow at the moment.
This (today) is welding on the new idler roller that I installed in 2016. So it has 600 hours on it in those 8 years. Did I really use it that much? This is not a professional machine !!
The new idler cost $230 +$45ship in 2016. Now they cost $400. I thought this worn idler had to be the original (Kubota) idler.
I’d better take a peek at the original idler one on the other side.
Maybe grease-fill the bearing????
If I were back in the shop and it was my unit and the bearings were fine, I would spray weld in a lathe to build up the surface.
Bearings on this idler spins smoothly.
This machine has the wrong tracks. Which appear to have a lot of life remaining. The “wrong tracks” have accelerated the wear on the rollers. The drive area is about 1/2” too wide so it doesn’t center on the rollers and wears stuff out.
All new tracks and rollers will cost
$500+3x$200 = $1100 (per side)
Add to that…. I’ve not seen proper A-width tracks available aftermarket. I have not checked on original Kubota track price nor availability. But from past experience I’m gonna guess it’s about 60% more $$$$, something towards an eye-popping $2500 per side.
Or milk the rollers along (with welding time).
Then run it out.
I have to dig this week. Prefer to keep moving.
Heres the easy side. One bead.
The other wear area will take at least 5 beads.
I don’t have a lathe and don’t think it requires much precision. Furthermore it doesn’t look like the roller can be disassembled to put in a lathe anyway.
I see a hex plug and will guess the track idler bearing is oil-filled too, like the rollers were.
