Low pressure curt off switches only work with big leaks. Small leaks will still flood the house. Plus, low pressure switches are a nuisance, as you have to go hold the lever to start the pump again after every power outage or every time the wife turns on one too many hoses.
The variable flow and constant pressure from a VFD is great, but VFD's do have "lots of features", which along with high cost is a big problem. All you want is water to come out of the faucets when opened, and the more "features" the controller has, the less likely water will come out when needed. Small leaks are not one of the features a VFD can protect from, as it just thinks you are running a drip system or something. There are some leak detectors that hard wire to the pressure switch, but they have to be close to the pressure switch as well.
If you have wifi, many options are available. I use an Aeotec heavy duty smart switch to send power to my pump. This switch is controlled by a Samsung smarthub. Not only can I see what my pump is doing, but am able to turn it on and off from my phone when needed. I use Samsung leak detectors all through the house and out buildings where there is water. Just a little moisture on any of these leak detectors and my pump turns off immediately. The biggest problem I have has is when my little granddaughter picks up one of the leak detectors and her little sweaty fingers shuts off the pump. Lol!!!
