westendorf brush crusher
   / westendorf brush crusher #21
The BC-4000 is the most universal unit, it has a set screw to secure it to your loader arm. We fit new loaders every day. There is a dimension sheet for loaders you'll need to fill out so we can verify arm end dimensions and cylinder stroke to make sure unit will close properly. PM me with email address and I'll send you the dim sheet. The BC-3000 approximate price is around $900 and the 4000 is around $1050. (Just to let you know, I am MFG, your local dealer prices may vary.)
   / westendorf brush crusher #22
Talked to a knowledgeable lady at Westendorf today who cleared up the mystery of a single grapple moving while the other was stationary! It is nothing more than the cylinder closest to the feed point absorbing the hydraulic flow. Any resistance to that movement will cause the other cylinder to move. From the Demo video, it just looks like individual control.
Just itching to give it a try but I'm 250 miles from the tractor at the moment so I'll have to wait to get the measurements
   / westendorf brush crusher #23
Is there a Brush Crusher to fit the single cylinder curl loaders, specifically the Kubota BX-24?
   / westendorf brush crusher #24
We are working on a modification for the single cylinder model loaders.
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
2014 Ford F-150 Pickup Truck (A55973)
2014 Ford F-150...
LOT: Receiver Hitches, 1/2 Ton Sheet Clamp, Pipe Threader (A59076)
LOT: Receiver...
2003 Freightliner FLD 120 Columbia (A56435)
2003 Freightliner...
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
MAGNUM LIGHT TOWER (A58214)
MAGNUM LIGHT TOWER...
