Wet sand blaster
   / Wet sand blaster #1
Paddy
Veteran Member
Bloomington, IN
Kubota, G5200, KAMA 454
Anyone with a compressor can buy a sand blaster kit. But my experience with my small compressor is I get about 20 sec of blasting and I have to wait for the tank to get back up to pressure. I saw Rural King has a device that works with your pressure washer to "wet blast". In my mind, advantages are the power washer will work continuous vs. compressor recharge.
anyone try it? My pressure washer is a Simpson 2900 psi with 2.4 gal/min. I'm hoping it's enough
Rural king has this type for under $70; Valley Industries Wet Sandblast Kit SBK-400
   / Wet sand blaster #2
I have a high volume industrial pressure washer. I have a wet blaster attachment. It works alright. Many things you blast, you don't want getting wet as you probably want to get paint on them ASAP! When you dry blast something, that is the perfect surface for paint. One problem as with all blasting is moisure in your medium. That (wet blaster) tube won't suck anymore medium if your medium get's wet and that can be a challenge when you are working close by with high pressure water.
   / Wet sand blaster
Industrial,
What brand did you buy? Also, I did hear it's important to keep the sand feed tube on the top side to reduce water from saturating the sand.
You are correct about wet steel flash rusting. I'm hoping I can wipe it off after the cleaning
   / Wet sand blaster #4
I bought one a long time ago. It works, but it makes a real mess. I used it once and haven't touched it since.
   / Wet sand blaster #5
I have one, works well. Flash rust is a big issue get and use 100% denatured alcohol and wipe or spray immediately after cleaning.
   / Wet sand blaster #6
I have one tried it, worked?, you want it I'll send it to you. Agree with others. Have you looked at soda blasting? I don't do it that way, but I use a ceramic soda blast tip in my cabinet blaster, I can regulate PSI down to 80 psi, compressor doesn't like it but it is working. I use it to clean parts before powder coating. Won't blow paint off use chemical stripper for paint. Then just blow it off with the pressure washer.
   / Wet sand blaster #7
I am not sure what brand it was, but something respectable. Bought it from an industrial spray painting supply shop for around a hundred bucks, about half price. Since then, I see them at the cheap tool places.
Funny, I have not used it for years, but I just came accross a badly rusted heavy steel piece for one of my on-going projects. I may just use it for that, and to try and blow the concrete residue off of a flat free wheel borough wheel someone just gave me.
   / Wet sand blaster
Air Compressors are so inefficient. Compare a die grinder to an angle grinder. And large compressors are not portable.
   / Wet sand blaster
Truck,
That's a generous offer. But there cheep enough. I plan to use one on several surfaces. I have some steel bar joists with concrete splatter an a bit of rust. I also will try a bit of limestone carving with it. I tried the power washer without the sand and it was pretty impressive.
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
2018 Wacker Neuson WL 38 (A51039)
2018 Wacker Neuson...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
2022 Case IH 8250 4WD Combine (A50657)
2022 Case IH 8250...
