What GPM hydraulic pump is needed for 2" bore cylinder?
   / What GPM hydraulic pump is needed for 2" bore cylinder? #1
chad22
Kansas
Sears Garden Tractor
I bought one of these cylinders that's in the link for my backhoe that I'm building. It has a 2" Bore. I'm wondering what size (GPM) of pump would I need to make the cylinder have good retract and extend times?
Delvan Ag Pumps Inc 2 X 10 Tie-Rod Hydraulic Cylinder
Thanks
Chad
   / What GPM hydraulic pump is needed for 2" bore cylinder? #2
If you are talking about a small backhoe I would think 5 gallons per minute is about right.
Any pics of the placement of the cylinder would be helpful.
Craig Clayton
   / What GPM hydraulic pump is needed for 2" bore cylinder? #3
Thanks
Chad
Assume 1 in rod,
4 GPM = 2.04 sec extend
1.53 sec retract.
6 GPM= 1.35 sec extend
1.02 sec retract
At 2500 psi, push force would be 7854 lbs
pull force -----------5890 lbs
   / What GPM hydraulic pump is needed for 2" bore cylinder? #5
hey AKK, did you build that spreed sheet? I like it :thumbsup:
   / What GPM hydraulic pump is needed for 2" bore cylinder? #6
I could see some was in there and tried a 2500psi 5" bore....LOL....Tx sylwoody....Yes I make'm.....call it my X-mas gift to ya all....:thumbsup:
   / What GPM hydraulic pump is needed for 2" bore cylinder? #8
Got a little spread sheet here, try that!!
Enter you numbers in the green cells, GPM is a function of displacement and speed in this spread sheet...
BTW, Merry X-mas everone!!
Wow. that makes my spreadsheets look lame. Same results though. I am always comming up with new things to enter.
I have one for logsplitter force and cycle times. Log splitter questions come up here fairly often. But mine dont look that good, or colored in either:D
   / What GPM hydraulic pump is needed for 2" bore cylinder? #9
I have this one for two stage pumps too....I think it can be useful when matching pump and engine/motor
   / What GPM hydraulic pump is needed for 2" bore cylinder? #10
Boy I am glad I replied to this thread. It is now in my "subscribed" list and It will be easier to find when I need one of these charts. Shure beats doing it by hand or creating another spread sheet:thumbsup::thumbsup:
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2014 FREIGHTLINER...
2023 Chevrolet Tahoe (A54815)
2023 Chevrolet...
Toro Ground Master 4000D (A56857)
Toro Ground Master...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
NEW Landhonor 5400LB Ratchet Binders & G70 Chains (A59000)
NEW Landhonor...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
