Travelover
Elite Member
I've got a weird problem. Suddenly I have air in the water lines in my house, especially the hot water lines.
I have a well and rather than a bladder tank, it has an air control valve tank which means it keeps a specified amount of air in the pressure storage tank at all times and bleeds off any excess air via a float control inside the tank. Air is introduced into the tank via a couple of check valves in the drop pipe. The tank seems to be operating properly as I can draw a lot of water off the tank before the pump kicks on. It seems like air and water should be separated within the tank and not feed into the lines.
I'm wondering if a second possibility might be a broken dip tube in the water heater. If air collected in the top of the water heater and the dip tube was broken off air could enter the outlet. The usual symptoms of a broken dip tube are not there - it gives plenty of hot water at a constant temperature and no plastic bits are in the faucet aerators. This also wouldn't explain occasion air in the cold water pipes.
Anyone had a similar issue?
