What To Buy ??
   / What To Buy ?? #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST,
After Our snow/ice storm. For xtra traction, I need to get some chains or cables for the rear tires on my truck. Never bought any and have no idea which is the best for traction / ride.. So,,,,, you guys north of me that get a lot of snow / ice,,, Which is the best snow chains or cables ??
   / What To Buy ?? #2
I'd buy better tires or put a thousand pounds in the bed. My 2wd open diff f250 is Terrible empty, but hardly slips full of firewood. I run bf Goodrich at tires. Chains are awful at any sort of speed.
   / What To Buy ?? #3
Get tires. I have used chains and studs but a set of Snow Tires is they best money spent.
Chris
   / What To Buy ??
Due to the little snow/ ice that we get ( every few yrs) The tires would dry rot B-4 I wore them out. I don't want to run snow tires yr round. No more snow / ice that we get,,,Chains / cables would last forever and be a less expensive option for occasional use. Don't know if snow tires would even help. I snow is very wet and quickly turns to ice
   / What To Buy ?? #5
Well, I don't think you'll get any brand recommendations from us guys up here. I've never seen a set of chains on a car or truck in these parts. They are definitely illegal. I've seen them out west, where you have to have them in the car to cross the mountain passes. Again, you really can't go above 20-25 mph. How much weight do you have in the bed? Sand bags are cheaper than chains.
   / What To Buy ?? #6
chains aren't used for commuting. the only ones in use here are for plow/yard trucks. better tires and weight are the only answer. as was said, you can't maintain speed and control with them, and they're most likely illegal where you live. myself and a lot of people i know do run specific tires for the winter months, but the bulk of the people here run the same all season tire year round. it may not be as good, but if you don't want to buy different tires then you don't have much choice.
   / What To Buy ?? #7
There's your answer. Weight and tires for the win. You don't have to get dedicated snow tires for occasional use, just get a tire with better ice/snow ratings and run year round. The weight in the bed makes any tire perform better. Also, don't inflate the tires to max for ice/snow. Keep them on the low end of your normal range and you'll have more bite.
   / What To Buy ?? #8
BFG A/T's have been my year round "go to" tire for all my previous light duty trucks. Ran them on everything from F-250's to 1500 Silverado's. They clean out well in snow and mud and are quiet on the road. Pulled a 34ft. 5th wheel about every other weekend in the warm months w my wife's F-250 when we lived in GA and still got 50k out of em with tread left. Wear was even on all 5 sets I have owned. The side walls are stiff enough to air down for extra traction in snow also. When the Bridgstone A/T's wear out on the new Suburban, they will be replaced w BFG A/T's. Edit: Just remembered they come factory on the Ford Raptor. My 03 GMC High Rider ZR-2 came w them also. http://www.bfgoodrichtires.com/tire-selector/category/off-road-tires/all-terrain-t-a-ko/tire-details image-500495922.jpg image-4179672520.jpg
   / What To Buy ??
I currently have Toyo open country tires. I lowered my tire pressure to 40 PSI. I still slid around some. Kept it in 4WD the entire time I was out driving. I just thought I may do a little better with chains or the cables that go on tires. I have an old septic tank top that I may drill a hole in, add a chain so , when the next snow/ice storm comes, I can use the tractor and load this chunk of concrete in the bed . Thanks for the suggestions. We don't get that much snow/ice down here and wanted to know what the experts that drive in this stuff use Again ,,,thanks
Peterbilt (A51692)
Peterbilt (A51692)
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2007 Yamaha Rhino 660 (A55315)
2007 Yamaha Rhino...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
2017 Nissan Frontier Ext. Cab Pickup Truck (A55852)
2017 Nissan...
2013 ISUZU NPR STAKE BODY TRUCK (A56138)
2013 ISUZU NPR...
