Whats the most hours you've seen on a 4000 series tractor?
   / Whats the most hours you've seen on a 4000 series tractor? #21
2000 4600HST with 2000+ hours.
   / Whats the most hours you've seen on a 4000 series tractor? #22
Our highest current Jd is a 445 with 1500 hours on it and heck that's a gas lawnmower! Im certain the big diesel tractors will go for 1000s of hours.
   / Whats the most hours you've seen on a 4000 series tractor? #23
01 4300 HST with 2100+
   / Whats the most hours you've seen on a 4000 series tractor? #24
I run a 1997 4400 at work and its got 4600 hours on it, shuttle shift, with sync reverse. Engine seems to run strong still.. Shes leaks like the titanic.. and the loader needs pins, bushings, shims and a new tractor. :)
   / Whats the most hours you've seen on a 4000 series tractor? #25
i have seen a bunch of 5000 series tractors with over 15000 hrs on them.
   / Whats the most hours you've seen on a 4000 series tractor? #26
Just got me a 2009 4720 w/ ehydro trans with 1300 hrs on it. Still runs very strong and no smoke. Only real problem I can tell is that the loader (400cx self leverer) pins seem very sloppy or wore out. Is this normal for this loader?
   / Whats the most hours you've seen on a 4000 series tractor? #27
Not to press the issue but the op asked about 4x20, very different machine then the 5000. Very different mechanically and often used in different ways. I do think that the small displacement of cuts and scuts could lower engine life, a little...
   / Whats the most hours you've seen on a 4000 series tractor? #28
Ok maybe that came off as a bit rude, I am just thinking that based on what I know I would be surprised if the 4000 hold up like the 5000, even with less ground engagement work...hopefully I am wrong cause I currently run a 4320...
   / Whats the most hours you've seen on a 4000 series tractor? #29
Update
I have a 4005 with 28.5 hours on it. It has a collar shift manual cast iron housing transmission. I drive it to the Post Office to check the mail ....
Joe
My 4005 now has 297.0 hours on it ... still doing well, going strong!
I will have had it two (2) years come June; it's a wonderful work horse. I cut with a MX6; I plough with a 3-16 bottom plough; I pull a single shank subsoiler to the top of the mast; I till with a 673 Tiller. It has not failed to do as I ask of it.
Joe :D
   / Whats the most hours you've seen on a 4000 series tractor? #30
Have 4500 850 hours, powerevesr trans
2023 54in Hooklift Dumpster 15 Cubic Yard (A56858)
2023 54in Hooklift...
Forklift Telescopic Boom W/11ft Extension (New/Unused) (A59225)
Forklift...
More info coming soon! (A56859)
More info coming...
2016 Ford Expedition SUV (A56859)
2016 Ford...
2313 (A58376)
2313 (A58376)
2011 Ford Escape XLT SUV (A54815)
2011 Ford Escape...
