Where are all the CUMMINS fans?!
   / Where are all the CUMMINS fans?! #71
Hiya,
I'm here. Mine is an old '92 W250, 12 valve that's basically stock w/175K on it. Runs great. The injector pump went south at 90K but because I took the service managers advice right after I bought it and waited to do the pump recall the early 92's had when it died, it was a freebie on Dodge. Other troubles it has given me is it ripped the lugs off the converter and snapped the flexplate at 110K. The only other thing is I can't keep U joints in it longer than a year.
It has the 47rh (I think) in it. I change the fluid (Amsoil) and adjust the bands once a year and it still shifts like new. (Actually it shifts better than new, I put a Fairbanks shift kit in it the first time I had the pan off the trans) I fully expect to get another 175K out of the trans.
OK, my 23 cents,
Tom
   / Where are all the CUMMINS fans?! #72
It was one year ago this month that I searched everywhere for an 07' Ram with the 5.9 Cummins. Found two of them in Oregon and bought one sight unseen. This was after hearing all the negative reports about the 6.7.
Boy am I glad I made that decision.
Kubota R5205 (A57148)
2019 Kubota RTV500 (A57149)
2019 Kubota RTV500...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PNEUMATIC GREASE UNIT (A58216)
PNEUMATIC GREASE...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
