Where is the hydralic fluid level check?
   / Where is the hydralic fluid level check? #1
possum_hollow
Oklahoma
Mahindra 4530, Kubota 7040
Have a new 4530 Mahindra, and it is working out very well. But I have a question. I have been completely through the manual, and cannot find where to check the hydralic fluid level. Any one out there know?
Thanks!!
   / Where is the hydralic fluid level check? #2
On my 6000 it is in the back above the pto shaft, has a dipstick with a ring on it. Just pop it out, it is a little difficult to see.
   / Where is the hydralic fluid level check? #3
On my 2810 HST it is a sight glass just up and to the left of the PTO
Dave in NH
I again went over the manual, and found the following passage in the section on the transmission:
"The oil and reservoir is common for Transmission, Hydraulics and Steering"
However, in the specification section it states:
"Fully 'live' hydraulic pump & separate reservoir"
So, I am still somewhat at a loss.
   / Where is the hydralic fluid level check? #5
Don't know if yours is different, but my old 5005 has a square nut on the right top of the reservoir behind the seat. You unscrew the square nut and there is a dipstick attached to it.
   / Where is the hydralic fluid level check? #6
If you can't find it in the manual I'd be calling the dealer. You'll have an answer right away.
   / Where is the hydralic fluid level check? #7
Actually, that's the way it is on the 6000 as well. The pull out (with the O-ring) is to check the transmission gear oil. The hyd check on the '00 series and possibly the 4530, is the plug to the right and under the rear of the seat (I think its a 4 sided about 1/2 inch open end job)....BobG in VA
   / Where is the hydralic fluid level check? #8
This is where the level and fill is on the 00 series as Bob is describing. Sorry, you can tell I didn't take this picture for this purpose but it should give you an idea.
   / Where is the hydralic fluid level check? #9
I have been off from work with knee surgery, so I haven't had my books to look up the location of the fluid level check. Also I can't remember the exact location, but I can tell you the 00 series is different. The 30 series has a common sump for the hydraulic and transmission/rear axil. The 00 series has the separate sump for the hydraulics. When I get back to work I will look it up and let you know where it is, if no one else has given you the answer by then.
Galen LaWall
Your Mahindra Tractor Dealer
Batavia, NY
585-343-0770
   / Where is the hydralic fluid level check? #10
I HAVE A 4530 ALSO, THE HYDRALIC LEVEL CHECK IS ON THE LEFT SIDE JUST IN FROUNT OF YOUR STEP ITS THE SAME AS Transmission and power Steering.
2022 CATERPILLAR 903D WHEEL LOADER (A52709)
2022 CATERPILLAR...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2019 John Deer 3038E 4 x 4 Tractor w/300 E Loader, S/N 1LV3038EJKK126097, Diesel Engine, Joystick (A59076)
2019 John Deer...
Mini Excavator Quick Coupler (A55272)
Mini Excavator...
2002 Lexus SC430 (A57148)
2002 Lexus SC430...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58216)
2013 TEXAS PRIDE...
