Where's the oil drain on mtd tiller 550 series Briggs.
   / Where's the oil drain on mtd tiller 550 series Briggs. #1
yelbike
Near Winnipeg, Mb, Canada
John Deere 2305, 2320,Z465
There is no oil drain plug to be seen. Should I just tip it over and spill the oil out of the filler neck?
   / Where's the oil drain on mtd tiller 550 series Briggs. #2
I have a new self-propelled lawn mower with a Honda engine. Couldn't find an oil drain plug either, so I checked the user manual and it said to tip the mower over to drain the oil out of the same place it is put in. I suppose there is some lodgic behind this method or it's a cheaper way to produce the engine. I would perfer a drain plug on the bottom to help drain any metal shavings or settling of dirt, etc.
Its not my tiller, trying to help a friend. But vaguely remember doing this on old mtd mower.
   / Where's the oil drain on mtd tiller 550 series Briggs. #4
Briggs has removed the oil plug on select engines. The reasoning behing it was when used on pushmowers, some of the newer deck designed prevent using a drain plug on the bottom, so through engineering briggs has removed the drain plug from the mold.
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
42013 (A51691)
42013 (A51691)
2015 Honda Accord Sedan (A53424)
2015 Honda Accord...
2015 Jeep Cherokee Latitude SUV (A55758)
2015 Jeep Cherokee...
2025 JMR 40in Brush Grapple Skid Steer Attachment (A55851)
2025 JMR 40in...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
