namesray
Platinum Member
ok. a while ago here on tbn, I read about the concern of cavitation within a diesel engine cooling system if the proper coolant, or coolant additives, SCA's (supplemental coolant additives) are NOT used. since then, I have been doing a little further research and I would like some more help figuring this one out. I have been flushing my Kubota engines coolant every 2 years as op manual states. I have been using the prestone universal coolant that states safe for all metals (including aluminum). haven't noticed any ill effects for 6+ years (1200 hours), but what I hear about cavitation, I wouldn't until its too late. the Kubota book says to use fresh clean water and antifreeze. dealer says any antifreeze that states safe for all metals is fine. Kubota website only states fresh water and antifreeze. both say nothing about SCA's to prevent cavitation. the closest specific I can come up with is in the op manuel, it states coolant should refer to SAE J1034, more specifically SAEJ814c. the prestone I have been using states it meets astm d3306. (whatever all these sae and astm's mean??????) after looking around at local stores, I found this product, fleet charge
What's New!
states it comes with the proper initial amount of SCA's and don't even need to worry if distilled water is used or not for the 50/50 mix due to an anti scaling additive. fleet charge meets the sae j1034, but also the astm d3306. would this fleet charge product be the better choice over the prestone universal I have been using, or am I over thinking again. this fleet charge is the only coolant with the SCA's that is readily available in my area. most people I talk with around my area about SCA's and cavitation don't have a clue to what I am asking or talking about. the ones who do understand, have given me mixed answers. what do you all think. please help as I am trying to learn this. thanks.
What's New!
