Comparison Which manufacturer has the highest HP true HST tractor?
   / Which manufacturer has the highest HP true HST tractor? #11
AS LouNY said, you will have a hard time to find agricultural tractors 60+ HP with HST it is not robust enough for that, but you'll find KVT in the case of Kubota or CVT in other makes or PS (power shift)
800+ hp dozers run HSTs. It's not that they aren't strong enough. It's that bigger than CUTs efficiency matters a bit more than convenience. Bigger machines tend to be ag machines rather than utility machines.
   / Which manufacturer has the highest HP true HST tractor? #12
I was under the impression that most of them where 3 or 4 speed automatics or power shift transmissions.
Which ones are hydrostatics?
   / Which manufacturer has the highest HP true HST tractor? #13
Many large Ag tractors are Infinitely Variable. Probably not oil driven. Too much heat and hp loss. Not to mention noise!
   / Which manufacturer has the highest HP true HST tractor? #15
Ya, good article. It's from 2007, so not exactly a recent development either (regarding lots of HSTs in big machines). The downside to HST has always been cost/complexity & efficiency.
Sometimes it's worth it (big time for CUTs) when precise control & manuverability is paramount. Sometimes not (big ag tractors) where they just pull a huge plow or impliment in circles all day at the same speed.
I think the current crop of CVTs is closing in on the efficiency of geared machines while still giving the control of a HST. I havent seen any in the CUT market yet, but I believe there are a handful in the UT range. Not sure what the price premium is, but I bet it's a bit as essentially you have a small HST ontop of a geared transmission that's more complex than a clunker 3 speed on every HST (at least in the CUT range).
   / Which manufacturer has the highest HP true HST tractor? #16
The noise must come from bad design, larger equipment with hydrostatic drive dosent whine like microtractors, know only one Kubota BX and the noise is very unpleasant.
   / Which manufacturer has the highest HP true HST tractor? #17
Fendt 207 Vario has the best transmission there is, stepless from 0.02 to 40km/h but not particularly cheap to buy.
..And all the way up to the 1050 Vario with 500hp.
   / Which manufacturer has the highest HP true HST tractor? #18
Yes, Fendt is very popular here I live.
   / Which manufacturer has the highest HP true HST tractor? #20
you wont find one in the 60hp range as far as pto HP is concerned
2004 AGCO Gleaner 3000 Corn Header (A57024)
2004 AGCO Gleaner...
2013 Infiniti G37 Coupe (A55853)
2013 Infiniti G37...
2020 FREIGHTLINER M2 26' BOX TRUCK (A57192)
2020 FREIGHTLINER...
2005 Autocar WXR Heil Rear Loader Garbage Truck (A55852)
2005 Autocar WXR...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
