Comparison Which manufacturer has the highest HP true HST tractor?
   / Which manufacturer has the highest HP true HST tractor? #51
I'm not sure about the Command8 that John Deere puts in the new 5R series. Starting at 90 Hp.
   / Which manufacturer has the highest HP true HST tractor? #52
I see, well Deutz-Fahr makes the 5100 TTV with a SAME manufactured transmission and the 3.6 four cylinder in that model puts out around 70hp
Interesting tractor, upscale in many respects, surprised at the tire size being so small, 16" front and 24"rear rims.
Also the 5100 TTV is not available in the US it is a Canadian model only.
Also using the dealer search, 5 in Canada and only 1 in the US.
At one time some of the older Deutz were sold around here, not many and they were the air cooled.
I haven't seen a new Deutz in person in well over 30 years.
They look and read like a nice tractor, high end but nice.
   / Which manufacturer has the highest HP true HST tractor? #53
GST is just Kubota for power shuttle, at least on their CUTs. Wet clutch with a hydraulically shifted transmission. There is usually a dry clutch in there too, not that you strictly need it.
Personally I never got the feel for the engagement timing in the couple hours I ran a L3?30 GST my brothers father-in-law has. I ended up using the clutch a fair bit. Probably would have gotten mostly onto the shuttle lever with a few more hours of seat time. Good transmissions, but still a bit more of a learning curve than HST, especially for precision work.
I learned to drive a tractor with a Massey Industrial 30, so I still use a clutch out of habit, but I don't need to use it.
Aaron Z
1994 International 3800 Bus (A54814)
1994 International...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A55301)
3-Point Hitch Root...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Bus (A55852)
2000 Thomas Built...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
2017 Nissan Titan (A55788)
2017 Nissan Titan...
