Mowing Which mower type should I buy for my Cub 7264?
   / Which mower type should I buy for my Cub 7264? #1
JamiDoug
Central Ohio
I'm getting ready to purchase a Cub Cadet 7264 with a FEL and mower. My dilemma is which mower to buy for the work I need to do. /forums/images/graemlins/confused.gif I'll be seeding and finish mowing about 3 acres. The remaining two acres will be pasture grasses, weeds, etc. The pasture is mostly clear of rocks, large sticks, and such.
It kinda goes without saying that I'll need a finish mower for the lawn. Can I get a finish mower that will also mow the taller pasture grasses and still stay in good enough condition to do a nice job with the lawn?
If a finish mower will get the job done, would you recommend a mid-mount or a 3pt finish mower? What about discharge? Side or rear?
If I need to purchase a rough-cut mower in addition to the finish mower, will the 7264 (21HP PTO) handle a 60" or will I need to back down to a 48"?
Thanks everyone! /forums/images/graemlins/smile.gif
Doug
   / Which mower type should I buy for my Cub 7264? #2
<font color="blue"> Can I get a finish mower that will also mow the taller pasture grasses and still stay in good enough condition to do a nice job with the lawn?
</font>
I have tried my MMM to cut the field next door to my house. With the weeds around 12" the cut was worse than my 60" Rotary Cutter.
<font color="blue"> If a finish mower will get the job done, would you recommend a mid-mount or a 3pt finish mower? What about discharge? Side or rear?
</font>
I prefer the MMM. Because it is easier to get close to obects without looking back to see the mower. I have never tried the rear discharge. My 72" MMM is side discharge. I would recommend a 72" for your tractor. That way the mower sticks out the side far enough to get close to items. One fault I have with a MMM is it's hard to get under my many pine trees. I now have a Front Mount mower that I use more than my <font color="orange"> Kubota </font> B2910 to cut lawn.
<font color="blue"> If I need to purchase a rough-cut mower in addition to the finish mower, will the 7264 (21HP PTO) handle a 60" or will I need to back down to a 48"? </font>
If all your going to do is cut a field as you describe a 60" will work. If you are going to do land clearing also a Heavy Duty 48" will be a better choice.
   / Which mower type should I buy for my Cub 7264? #3
I have a cub 7265 with a 72" Bush Hog RFM with rear discharge. I bought it to mow and maintain 4.5 acres. The first time I mowed it was about 1-2 ft tall. I was actually surprised at how nice the cut was. Did take sometime to get use to the RFM. I used a MMM for many years before that.
   / Which mower type should I buy for my Cub 7264? #4
So you decided to buy a Cub huh?
Congratulations!! Good luck with it. I would go with the 48" rough cut. You never know what you're going to get into.
   / Which mower type should I buy for my Cub 7264? #5
I would think a 60" finish mower would also cut the pasture grass, a 72" might do it. It really depends on how long it is and what is in there. I would not take a finish mower into the pasture IF there are lots of rocks or branches. You might want to get a RAKE and rake the pasture out, then inspect it to make sure there is nothing in there that will damage a finish mower (woody shrubs, saplings). Clear out anything that will cause damage, and then you are left with just tall grass. You can use a finish mower on that pasture, and after a couple of years of maintaining it, it will look like a decent lawn. You just want to make sure it is reasonably smooth, and it is free of debris.
Toolbox (A50860)
Toolbox (A50860)
2014 Ford Explorer AWD SUV (A48082)
2014 Ford Explorer...
2014 KALMAR 4X2 YARD DOG (A50854)
2014 KALMAR 4X2...
Sink with table (A50860)
Sink with table...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
