Item Details
Front Hub (Final Drive Planetary Support) for four wheel drive White and Iseki Tractors
Fits:
White 2-45 4x4
White 2-62 4x4 (Serial Number 00002 - 00496
Iseki T5000 4x4
Iseki T6500 4x4 (Early Models)
Agco Part Numbers
old part number 33-0028339
New part number 33-0038067
old part number 33-0049417
new part number 33-0045527
These units have been obsolete for years, and virtually impossible to find used.. They have been fabricated using all the specifications from the original hub and respective bearings.. They have been fabricated using 4140 steel and heat treated to 44rc on the Rockwell Scale which is slightly softer than the originals so that they are less brittle. To simplify production these were machined in two separate pieces (the flange where the wheel bolts on, and the splined hub that breaks) press fitted together, and welded which can be seen in the pictures.
I have personally installed each unit in my own personal tractor to verify fitment.. (The snap ring on the outer most bearing is a very snug fit). Keep in mind that the planetary assembly only fits on this hub one way!
$2000
I have 2 available.
Shipping available
Fits:
White 2-45 4x4
Iseki T5000 4x4
Agco Part Numbers
$2000
I have 2 available.
Shipping available
