Who do you like for a trailer manufacturer in the mid-south
/ Who do you like for a trailer manufacturer in the mid-south
If you have to get in lot's of tight places the bumper pull will win every time, it also allows the bed of your truck to be free to haul or carry other things, a bumper pull will track the truck more closely and you can get in pig trails and tight driveways that you can't with a gooseneck, those are the only two things that the bumper pull is advantageous over the GN. GN tows better is easier to balance/adjust load on and is just generally more of a pleasure to pull, a properly loaded GN is hardly noticeable to the driver rolling down the highway, the same can rarely be said about a bumper pull. I have both types as I have different needs that one trailer can't accommodate, evaluate what your needs will mostly be and go from there. Good luck.
So I might should prioritize the 400 miles of driving over the first and last 10 min in the lots?
/ Who do you like for a trailer manufacturer in the mid-south #102
If that's your normal deal absolutely, highway driving pulling the gooseneck will be night and day difference over the bumper pull.
/ Who do you like for a trailer manufacturer in the mid-south #103
If you can tow the loads you are required to tow, even with the heavier weight of the GN, always go with the GN,
unless
You have to constantly enter very narrow driveways that are 90 degrees to the road you are coming off of. Especially ones with pillars, mailboxes, boulders, etc.
The GN will “cut across” the corner and hit those objects. A BP will track almost directly behind the truck towing it.
The GN isn’t terrible on 90 degree turns, just something to keep in mind.
/ Who do you like for a trailer manufacturer in the mid-south #104
GN trailers seem to love tailgates on new trucks.
/ Who do you like for a trailer manufacturer in the mid-south #105
That ain't something that just started they been liking them from the time folks started pulling them.
/ Who do you like for a trailer manufacturer in the mid-south #107
...those are the only two things that the bumper pull is advantageous over the GN.
I would add the one thing I think a bumper pull has as an advantage, it can be used with a weight distributing hitch.
On the flip side, a bumper pull almost has to be used with a WD hitch for things to work correctly.
Yes, I love my gooseneck trailers.
/ Who do you like for a trailer manufacturer in the mid-south #108
A gooseneck is a weight distribution hitch. That’s the whole point it exists.
/ Who do you like for a trailer manufacturer in the mid-south #109
Umm, no. Not even close.
It does put the weight in a far more favorable spot, but that doesn't make it a WD hitch. I have occasionally thought about how to make a WD hitch for a gooseneck, but that's easier said than done if also wanting to be able to turn.
/ Who do you like for a trailer manufacturer in the mid-south #110
If not for weight distribution then why does it exist? It wasn’t for the fun of welding extra joints.
/ Who do you like for a trailer manufacturer in the mid-south #111
As mentioned earlier, a gooseneck does put the weight in a far more favorable spot, but that is quite different from a weight distributing hitch.
As its name strongly implies, a WD hitch transfers weight from the rear axle and distributes it to the front and trailer axles. A gooseneck doesn't do that.
I don't remember the story about the first fifth wheel, other than that it was literally a fifth wheel placed horizontally on the back of a tow vehicle. From there the step of moving the trailer ball to where a 5th wheel was surely came quite naturally.
After all, it doesn't exactly require a degree in engineering to see how a bumper pull affects the weight applied to a tow vehicle, or how a gooseneck applies it differently, just like a 5th wheel.
I really don't care why goosenecks exist, but am quite grateful that they do. Much like that I appreciate WD hitches when having to tow a bumper pull.
/ Who do you like for a trailer manufacturer in the mid-south #112
A gooseneck is mounted in front of the rear axel slightly so it does load the front axel. Class 8 trucks have taken it one step further with sliding hitches and sliding axels.
/ Who do you like for a trailer manufacturer in the mid-south #113
It's been a while since gooseneck hitches have been ahead of the drive axle. These days they're pretty much right above the axle, be it a factory setup in a pickup or an aftermarket flatbed.
Little to no weight ends up on the steer axle, but that's still superior to a bumper pull without a WD hitch.
When making the mount for a B&W gooseneck ball I couldn't even get it directly over the axle, but with a 23K axle it doesn't matter. And there's plenty of weight up front. The ball has to be removable for the 5th wheel to slide back to normal position.
/ Who do you like for a trailer manufacturer in the mid-south #114
I have never used a WD hitch in my whole life with all the bumper pull trailers that I have owned and pulled, sounds like I'm missing out lol.
/ Who do you like for a trailer manufacturer in the mid-south #115
I couldn't run without when having a very long extension for the receiver, due to a camper, then started out without on small (16') enclosed trailers.
Didn't take me long to get a good WD with active anti sway, which helped quite a bit with less than precise load placement, and was extremely helpful on the empty return trips. Passing tractor trailers was no fun without it.
With two 1,000 mile trips per month for a couple of years I got a fairly good feel for what worked and what didn't. I only wish I had switched over to gooseneck trailers earlier, even thought it would've meant getting rid of the shell on the pickup. Easily compensated for by a 2' longer trailer.
I ordered one this weekend. I did opt for the bumper pull for several reasons, but cost was high on the list. I also went ahead and ordered a set of AirLift airbags for my truck with an onboard compressor. It's amazing how hard it is to get exactly what you want even when custom ordering one. The only compromise I had to make was that the drive over fenders are about 3" higher than I would like. But they should still be fine.
/ Who do you like for a trailer manufacturer in the mid-south #117
Youre not gonna share details on brand, etc until ?? :unsure:
/ Who do you like for a trailer manufacturer in the mid-south #120
Nice to see decisions made! What's your lead time Mr. BigJohn?
2017 Hyundai Elantra Sedan (A61574)
2017 Hyundai...
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
Challenger 236/246/248 Skid Loader Parts and Service Manuals (A63117)
Challenger...
UNUSED INDUSTRIAS AMERICA 170-7' SCRAPE BLADE (A64280)
UNUSED INDUSTRIAS...
KMC 3pt 5' Rotary Tiller (A64119)
KMC 3pt 5' Rotary...
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
