Why did they put the loader valve lever lock there!?
   / Why did they put the loader valve lever lock there!? #1
Evil the Weasel
Platinum Member
Central NY
Kubota B2620
I accidentally locked it with my foot when backing up and the panic set in quick when the joystick froze. UGH. All better now.
   / Why did they put the loader valve lever lock there!? #2
I don't know, but you're scarin' me away from buying new--LOL!
Glad you got it figured out.
My Hoe
   / Why did they put the loader valve lever lock there!? #3
An example may be, if you shut off the tractor with the loader bucket raised up in the air and you want to lay in front of the tractor to fix something with the loader bucket up and out of the way.
Oh my :eek:! The safety police will be all over you. It is not safe to be under a loader supported only by the hydraulics. A hose could burst at any time causing the loader to rapidly fall.
   / Why did they put the loader valve lever lock there!? #5
'Long as you didn't have the FEL maxed out, it's nothing to worry about.
Our orange back-saver is a B2320, new this past July, and we're protective as all heck, so if that happened to either of us, we'd've wet ourselves too.
I don't think either of us has the required knee flex to do what you did...
But both my boss [wife] and I have caught all sorts of clothing on the PTO levers as we climb down off of it- an if'n it's runnning, the grinding gear sound makes you wanna cry...
I guess I should've boughten a bigger tractor so I had the room to dismount safely.
To: the other respondents- he dint aks why it had a lock for the hydro- just why is it where your foot can lock it unbeknownst to yourself...
   / Why did they put the loader valve lever lock there!? #6
The spool lock is NOT for locking up the loader for service. you need to block the cylinder for that. the lock is more of a convenience so that you don't bump the stick and dump something out of the bucket or similar action.
2008 Ford Crown Victoria Sedan (A48082)
2008 Ford Crown...
2003 John Deere 1600 Turbo Ride On Mower (A50860)
2003 John Deere...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
