300UGUY
Super Member
Best post of the year!!!!
I suppose the set it and forget it method works well when you are running 1 implement such as yourself. Unfortunately most of us run several implements which requires top link adjustments and occasionally the bottom link spread adjustments. That's why I can appreciate the "Walmart Special" stick on RV levels. Just stick em right next to the top link and it takes all of about 10 seconds to level things up without guessing. They definitely won't break the bank at a couple of bucks for a pair.
The blades on both my units get out of whack due to a tire on one side not having enough air pressure like the other three. Please include a dash mounted air pressure indicator for the tires !
I am talking about a midmount mower. I like the welding of the nuts idea, but can't imagine how i wound get them exactly the same. Plus when I switch between my Gator blades and the regular ones it always seems to be a different height. I don't know if this is normal or not, but I frequently take my deck off to scrape and clean it. It never seems to be level when I put it back on, hence the frustration of leveling. I do always check the tire pressure first though.
Sounds to me like you are talking about a 3 point attachment on a utility tractor and the OP (I think) is talking about a mid mount mower on a lawn tractor.
If you have a lawn like this you might want the cut a little more even.
OK ... 4 nuts welded to the 4 corners of the deck at exactly the same place (at height of blades inside ) .... insert 4 long bolts of the same length (height you want to cut grass to).... lower / raise deck till they all just touch the ground .... remove bolts ....
