Why I hate those steel traffic platers.
   / Why I hate those steel traffic platers. #1
John White
Newark, Oh
Bob Cat Ct335
I hate those 4x8 steel traffic plates they put on the road. Some time ago they were working on the road I was hauling gravel with my dump truck, that had one. I always try to hit them square on with all wheels or 2 wheels on and swing left a little with two off. This plate was placed about 2 ft. right of the center line. I had been driving over it for a few days delivering gravel to a job site. It was in a area with a double yellow line. I could not go right because I would be off the berm and a hole where they were working. I usually just swung in to the other lane slightly so I wouldn't hit it with my tires. This one day I had just swung a little to the left and a car was coming pretty fast and I had to get back in my lane. My inside rear tire caught the edge of it. It blew my tire and the force some how knocked the plate up and caught my rear brake line, also ripping the rear backing plate off. But that is not the bad part. There was some fellow following me real close and he had a old pick up made in the 30's. He had just got it out of a restoration shop. He had spent over $20k in having it restored. My truck somehow flipped that plate up and it caught his under carriage, hitting the transmission and busting it and caught the rear differential taking it out along with springs and hangers. The whole rear end was sitting in the road. I had to pull off in the first place I could. The people didn't want me leaving it there very long. I had a crew waiting on the gravel. I went to the shop and got a spare tire, repaired the brake line and finished my delivery. Later I replaced the backing plate. I contacted the police and they gave me the name of the insurance carrier and all they paid me was $75 for a used tire I had put on. I don't know the out come of the other fellow. The last I seen him he was sitting in the middle of the road, dumfounded as to what happened. There is another one the state has just put down where I have to cross it every day. They put asphalt around it but the big trucks have bowed it and the corner is sticking up. My pucker factor comes into play every time I have to cross it. It is placed at about a 45 degree angle and about 2 feet left of center. Not enough room to go right and hit it square and if you move left, you are in the line of traffic. You have all those over paid engineers working for the state and they cant come up with a solution. My redneck solution for improvement, would be to make it a law that all traffic plates put down would have to have a 12" radius cut on the corners. That would help a lot and prevent it from busting your tire. Any one on here reading this and works for the D.O.T let me know why this could not be done.
   / Why I hate those steel traffic platers. #2
I don't work for a DOT and I don't know how much margin those plates need to overlap the hole under them. However, I believe a lot of times the pavement or concrete is saw cut and then the hole excavated. This would mean the hole has square corners so round corners on the plates may not work.
I agree with you though, I always cringe when they are positioned so I might hit the corner when going over them.
   / Why I hate those steel traffic platers. #3
A simple solution would be to grind the sharp corners off on a bevel.
Contact your gov to get them to require the plates have sharp corners ground off before being placed in service.
   / Why I hate those steel traffic platers. #4
YOU hate them?...... Try doing the job I had one summer. I was the kid working UNDER a plate like you describe. Talk about scary, especially when a driver decides to do something special.
   / Why I hate those steel traffic platers. #5
In working on road projects for the last fifteen years, I have not had a problem with the edge of plates . When the plate is installed they need to secure plate and wedge the edges. The problem is that plates are straight and the road is not
I just don't see what the big deal would be about just simply rounding the corners some. That would help or eliminate busted tires. Tale a torch and round them off a little. I can just see the govt. turning a mole hill into a mountain to get anything done.
   / Why I hate those steel traffic platers. #7
how do you think motorcycle riders feel about those plates. Slippery when dry, death when wet. Bastard angles to cause your tires to skip sideways, etc..
   / Why I hate those steel traffic platers. #8
If using multiple plates the chopped corners will cause more problems.
Proper installation is the key for road plates
   / Why I hate those steel traffic platers. #9
You left out the motorists who will pass/run you over in a heartbeat. I slowed once years ago and pulled over to cross a set of angled RR tracks. The driver behind me took advantage of it to "split lanes" with his car, just as II hit the tracks.
   / Why I hate those steel traffic platers. #10
Since you can't do anything about the plates and you know where they are why not just slow down?
Kivel 48in Pallet Fork Attackhment (A49251)
Kivel 48in Pallet...
1/4" Universal Quick Attach Plate (A47371)
1/4" Universal...
2014 UTILITY DRY VAN TRAILER (A50046)
2014 UTILITY DRY...
APV PS800 M1 Cover Crop Seeder (A49251)
APV PS800 M1 Cover...
2002 Blue Bird F131612 Bus (A48081)
2002 Blue Bird...
Pair of Tractor Tires on Rims (A47164)
Pair of Tractor...
