Will the front 3 pt hitch, driveshaft,& 59" snowblower from a JD 3046R fit a JD 3720
   / Will the front 3 pt hitch, driveshaft,& 59" snowblower from a JD 3046R fit a JD 3720 #1
GreenTime
Bronze Member
North Dakota
JD 110TLB, JD 3720, JD Z997, Kubota L5740
I am looking at a used 2012 JD 3720 and another dealer has the blower from a JD 3046R.
Any other major changes on the the 3046R vs. the older JD 3720? Thanks.
   / Will the front 3 pt hitch, driveshaft,& 59" snowblower from a JD 3046R fit a JD 3720 #2
Re: Will the front 3 pt hitch, driveshaft,& 59" snowblower from a JD 3046R fit a JD 3
No changes, unless you have a mid mount deck for the 3x20 then you will need lvb24810 in addition to adapt the deck draft arms to work together with front 3 point.
   / Will the front 3 pt hitch, driveshaft,& 59" snowblower from a JD 3046R fit a JD 3720 #3
bird confirm that the 3720 has the mid pto, it's a bit expensive
to install, but doable
Mini Skidloader 44in Bucket (A49251)
Mini Skidloader...
2014 Chevrolet Equinox SUV (A46684)
2014 Chevrolet...
2008 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A46683)
2008 Peterbilt 384...
2019 Refurbished JLG 400S Boom Lift (A49339)
2019 Refurbished...
CountyLine 5ft Rear Grader Blade Attachment (A46683)
CountyLine 5ft...
2014 Volkswagen Jetta Sedan (A46684)
2014 Volkswagen...
