Woodland Mill vs. Woodmax chipper?
   / Woodland Mill vs. Woodmax chipper? #21
I was wondering bout "upsizing." I like the woodland mills. It did seem like a lot more HP is required compared to others.
I couldn't figure out any actual reason for that either. Flywheel weight are similar, pto-flywheel ratios looked similar... There might well be a good reason, but I couldn't find it :)
All of the woodland mills are Chinese imports BUT they are made to spec and final assembled in NA and they do seem to do a lot of good customer care. After a lot of thought last year I went with the WC-88. I found one person having a ton of problems with the TF810PRO (this guy has a bunch of videos
- along with a direct compare of the non "pro" 88
) - it seemed to be flexing enough he was having the blades impact the anvil and then things went south from there.
The Woodmaxx machines are in two lines, the premium USA made MX series and the Chinese import WM series. The MX objectively have a few features that seemed better (or at least fancier hah) than woodland mills especially in the hydraulic system. The WM series are made more like the woodland but don't seem to be quite as nice based on my read. Plus I have a few friends with other woodland mills products who raved about their service. I waffled a bit on the WC-88 vs the MX-8800 or the MX-9900 though.
I've read a bunch of reviews and I haven't really found many people unhappy with the legacy woodland mills WC or the woodmaxx MX machines.
There's some difference of opinion on whether the top (woodmaxx) on/off bar is better than the (woodland) bottom. My take, without having tried the top.., is that the top is less prone to accidentally getting turned off, but the bottom is easier to turn off so arguably a touch safer. Pick your poison.
You DO have to set them up a little and getting the knives set properly was admittedly a bit of a pain in the *, there's no way to get a feeler gauge in there in a practical way. I ended up finding a wire that was the right thickness in the scrap pile and used it as effectively a long feeler gauge and had my SO gently move the flywheel back and forth along the whole blade while I adjusted the anvil in and out then doubled checked on the next knife.. repeat twice.. Luckily she's patient with my after a lot of years of working together hah. If they're set to fine you'll take out the knives and if they're set to coarse they don't cut well and clog so that's critical.
My short list of things I wanted:
  • Hydraulic/Hydrostatic infeed (WC, WM, MX)
  • Clamshell blade access (WC, MX)
  • Mostly flat infeed (WC, WM, MX)
  • Four blades preferred (WC68/88, MX-9900, MX-8600)
  • 6" or larger infeed, not because I wanted to chip really large stuff, but tree tops go in easier.
  • I could run it safely on my tractor
  • It didn't completely break my bank
I don't think you'd go to wrong with either brand honestly, there's some preferences in there.. and a little pick how much you're willing to pay for what.
Great info! Thanks!! I was wondering what diff is in the woodmax model (usa vs. Chinese). Just like you, I'm looking for the wider opening just to process cedar tops, not bigger trunks. Just less limbing. That helps. I'm gonna put a call into woodmax. I just want to know ow why 8800 only has 2 blades and the 8600 and 9900 have 4. I find that odd. The 8600 would be fine but the intake isn't flat.
   / Woodland Mill vs. Woodmax chipper? #23
I bought the WoodMaxx MX8800 in 2021. It's really a nice piece of equipment that is well built. I like that the infeed roller is adjustable for speed (and reversing) and allows me to put the branch in and walk away to get another branch. Never chip wood much bigger than 3-4" but I bought this size to be able to not have to trim branches as much. I looked over the MX9900 specs recently and it has a few features I would have liked such as the ability to pivot the infeed chute out of the way to get to the knives and the foldable infeed chute for taking up less storage space. Neither of these features are on the MX8800. Not sure why 4 blades vs 2 on the two models but it probably takes less power with the 4 blade setup especially when chipping the big stuff. I'll be interested to hear WoodMaxx's response. I did have an issue at low hours with equipment setup as delivered but WoodMaxx stood behind the product and quickly addressed the issue. One thing I did notice is that the price is up about 50% from what I paid in 2021 - Yikes!
   / Woodland Mill vs. Woodmax chipper? #24
It's a good question, the 8800 has a 200lb flywheel vs the 120lb on the 8600 but doesn't go up a lot in HP requirements (the flywheels are all 24" but different thickness except the 9900 which is 26.5" diameter). I'm wondering if they did that so that it cuts less often to drop the load?
They also don't seem to list the flywheel speed on the 8600, the 8800 and 9900 say 1200rpm (which imho is spitting distance of the nominal 1000 for the woodland).
I personally like the look of the flatter infeed on the 8800 and 9900 vs the 8600 as well, but that seems to be a personal preference :D. I can see an argument either day depending on what you're putting in the thing.
Good to hear bout your experience. I didn't get the opportunity to call today. I will let you know what I learn. I need the horizontal feed for what I do.
   / Woodland Mill vs. Woodmax chipper? #26
I would think the flatter feed plate on models with the power infeed are easier to load since it is lower to the ground. At least it is for me. Wood chipping takes a lot of energy from the tractor and me!
   / Woodland Mill vs. Woodmax chipper? #27
Roasting the limbs and trunks takes little effort. Just a match and some kindling to get it going. My preferred method....lol
  • Good Post
Reactions: MJZ
Mine too. But, burning in OK is limited to select days that usually don't align with my schedule. Right temp, high humidity and little wind all happening on my days off is rare. makes hard to burn
   / Woodland Mill vs. Woodmax chipper? #29
Also an issue here, sort of. Municipalities like to stick their noses where they don't belong today, even out here in flyover country but I basically ignore them. I'm just careful where I roast, when I roast and how I roast....lol
Amazing what you can reduce a big pile of discarded wood to. Big wood = small ashes.
Speaking of big pile, little ash, I lost 20 plus rics of wood last week due to wildfires. The ash is what's left of white oak firewood
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2020 Freightliner M2 106 Elgin Eagle Series 4MF Street Sweeper Truck (A55852)
2020 Freightliner...
2017 FORD F550 XL SERVICE TRUCK (A57192)
2017 FORD F550 XL...
2007 INTERNATIONAL 4300 26FT BOX TRUCK (A56138)
2007 INTERNATIONAL...
2022 John Deere 5075E MFWD Tractor (A53485)
2022 John Deere...
2003 Big Tex 10PI...
