X748 leaking oil
   / X748 leaking oil #1
orwell
orwell,ny
X748
I have a 10 year old JD X748 with the 3cyl 0.9L Yanmar that has started leaking oil. Oil appears to be coming from behind the flywheel area near the front of the engine. Any idea what I'm looking at and is this a common problem?
   / X748 leaking oil #2
It's a known issue. Age related.
The crankshaft seal can leak and manifests as you describe.
Not hard to fix.
Remove hood.
Remove battery.
Unbolt flywheel.
That gives access to the seal in its carrier housing.
Remove housing and seal complete.
Replace seal. Press fit.
Reassemble in reverse order.
RTV silicone on carrier housing mounting flange.
Torque flywheel bolts evenly.
   / X748 leaking oil
Not hard to fix.
Remove hood.
Remove battery.
Unbolt flywheel.
Thank you for the reply. I'll give this a try.
2013 FELLING  SKINNYNECK TA LOWBOY (A50854)
2013 FELLING...
VOLVO L45G WHEEL LOADER (A51242)
VOLVO L45G WHEEL...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A50860)
2012 Big Tex T/A...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
Lincoln Electric Vantage 300 Welder/Generator (A49461)
Lincoln Electric...
