XG3025H ant other owners out there?
   / XG3025H ant other owners out there? #61
The tractors amaze me I have not taken out any thing that big. I think I going to put backhoe attachment on wish list
   / XG3025H ant other owners out there? #62
I learned from the head sales guy that the back hoe should be only the size which the tractor's hydro pump can work.
Also I do most of the work w/ the 9 inch bucket (3 teeth). Our 18 inch bucket is used for digging sand.
The massive roots under some of these old trees have to be picket at nearly one at a time.
I have learned that some old pine trees will drop several tap roots right along side the main tap.
Some of the secondary tap roots went down & easy 6 ft. When you start on one of these old buggers you're usually there digging, cutting & pulling out to locate the main big anchor.
   / XG3025H ant other owners out there? #63
Put the new tire rod on today, then put about 6 more hours on the meter. If I get a hoe it be self contained
   / XG3025H ant other owners out there? #64
Self contained....does this mean it could be run totally independent of a tractor?
Perhaps from the back of a strong trailer, if anchored & the out pads could reach the ground ?
   / XG3025H ant other owners out there? #65
The ones I saw online use the 3 point hitch and uses the problem to run it own pump
   / XG3025H ant other owners out there? #67
I think by self contained you are thinking of a BH with its own hydraulic tank and a PTO driven pump. I have a Woods BH750 that has its own self contained hydraulic system driven by a PTO pump. It can be 3 pt. mounted and used that way but I'd strongly suggest it be mounted to its own sub frame bolted to the tractor. A BH can put a lot of stress on smaller tractors so they should be sub frame mounted for strength. Mine came with a sub frame for a different tractor. I adapted that frame to my tractor.
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2011 Ram 1500 4x4...
JLG 460 SJ TELESCOPIC MAN LIFT (A52707)
JLG 460 SJ...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
2008 KALMER 4X2 SPOTTER TRUCK (A54756)
2008 KALMER 4X2...
