Yanmar 150d workshop manual/ loader manual
   / Yanmar 150d workshop manual/ loader manual #21
   / Yanmar 150d workshop manual/ loader manual #22
Very possible the YM150 is a cobbled together tractor as stated in Hoyes avoid list. It clearly starts life as a YM1300D.
   / Yanmar 150d workshop manual/ loader manual #23
Who do you suppose made up the YM150D hood banner and why?
   / Yanmar 150d workshop manual/ loader manual #24
Don't know but Hoyes shows a YM150 as an avoid tractor as it is Korean made according to them but in reality it is a YM1300 which is a Jap grey market in this case.
   / Yanmar 150d workshop manual/ loader manual #25
And you know this how? This tractor has an external air filter. The YM1300 does not.
   / Yanmar 150d workshop manual/ loader manual #26
And I think the external air cleaner uses a different intake manifold, if its like my similar YM186D where the manifold has a flat flange where it emerges from the side cover and the donaldson filter is bolted to that.
So it appears to me this might be a YM1300 with YM155 components used as needed to overhaul it. Who knows where the YM150 hood decals came from, maybe Ebay.
   / Yanmar 150d workshop manual/ loader manual #27
I'm with Normde thinking maybe the Korean YM150. No reason to have a YM150 hood decal or where would it even come from?
   / Yanmar 150d workshop manual/ loader manual #29
On the Trans.13000-xxxx or 1300D-xxxx and stamped which should be correct. But he also said there wasn't a Ser. # Plate on the Eng. Block. With that being gone who knows what Eng. was used or what all was cobled together. It's really sounding like a Frankenstienermar.
Well am going to call a 1300D for now. Next problem is the axle leak on the front axle gear case. Does anyone have anything to share on changing the axle seal ? (should I start another post with a different title?) Got a seal from aftermarket seal and hydraulics supplier.(SKF), but have not been able to get a workshop manual, only have the parts manual for 155D, which looks identical for front axle so any help appreciated. Boltz
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2018 CATERPILLAR 299D2 XHP SKID STEER (A52709)
2018 CATERPILLAR...
3PT SUBSOILER (A52708)
Toyota 7FGU35 8,000lb. Propane Forklift (A55973)
Toyota 7FGU35...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
Kubota LX2620 (A53317)
