Yanmar 1700B Voltage Regulator
   / Yanmar 1700B Voltage Regulator #13
Go to Autozone and get one for a 72 Datsun. Same thing. Under $20. The plug matches, but ignore mismatched wire colors.
Here's more proof of the regulator and connector comparing a Datsun 1200.
Tech Wiki - Voltage regulator : Datsun 1200 Club
Aftermarket
RockAuto Parts Catalog
Datsun 1200 Wiring Diagrams - Datsun Forum (aka the 1972 Nissan Sentra)
* Standard Motor Products VR121 $30 USD
* Airtex/Wells 1V1250 $18 USD
* AC Delco E661 (88925052) $40
* GP Sorensen 265003 $48 USD
   / Yanmar 1700B Voltage Regulator #14
Take the Old Alternator with you and have them check it. Hate for you to cut up the Wiring Harness to find out you just had a bad connection some where. Or the alternator is bad. I found out I have both on mine. And the old style regulator still works fine. My Alt. light would start to flash random and after knowing everything was good I found the Loose connection on the back of the Fuse panel.
   / Yanmar 1700B Voltage Regulator #15
No need to cut any wires. The Wells regulator has the same plug as what you took out. It's a direct replacement just made from solid-state electronics in place of old school mechanical relays. Use one or more of the existing mounting holes. Done.
Yanmar simply went to Hitachi and sourced the same alternator/regulator combo that Hitachi sold to Datsun/Nissan. (Except for Datsun its a 30 amp alternator in the same enclosure; for Yanmar only 5 ? amps). I've run this replacement set since 2003 on the YM240 and it works like new - because it really is the same thing Yanmar specified in the first place.
Pro tip: if you want a 35 amp alternator spec 72 Datsun with Air Conditioning. I think that alternator is fatter and will need a longer belt and adjustment arm, but it used the same regulator. The 30 amp output of the basic model (Datsun without A/C) is plenty unless you have have added massive additional lighting for night snowplowing etc.
I agree with Carey's suggestion to take both the alternator and the regulator to Autozone where they will test them for free, before buying anything.
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2003 Mitsubishi Fuso FH (A57148)
2003 Mitsubishi...
PALLETS OF HEAVYEQUIPMENT (A58216)
PALLETS OF...
3-5TH WHEEL PLATES (A58216)
3-5TH WHEEL PLATES...
backhoe attachment for full size skid steer (A56857)
backhoe attachment...
2004 Cat 730 Articulating Off-road Dump Truck (A59213)
2004 Cat 730...
