tallyho8
Super Member
- Joined
- Aug 1, 2004
- Messages
- 5,256
- Tractor
- Kubota L4400, Kubota ZD326
tractorErnie said:Tally,
Have you by any chance replaced ALL the rubber fuel lines ? Missing any copper washers from the banjo fittings to the injector pump? checked all the injectors for proper spray and that they are tight? Pulled the side door open on the injector pump & check that all looks ok while you move the throtle handle back & forth. finally, have you WAVED your magic japanese keychain we sent you over the engine, while burning incense and rocking out with Hendrix over the speakers?
1. Have replaced all the rubber fuel lines.
2. Don't know if washers are missing but it has been running fine for years and I never took it apart.
3. Will get injectors checked tomorrow. I am not qualified to check them.
4. With my limited knowledge of diesels I have been afraid to touch the injector pump.
5. I got the keychain because my diesel truck had so much tire trouble. I did the full routine with the magic keychain on my F250 and have had no trouble since.
