Yanmar loses power, slows down & kills
   / Yanmar loses power, slows down & kills #141
If injection pump was rebuilt correctly than I do not believe compression can leak from cylinders to fuel system.
NOTE: in order for gravity filling of injection lines the delivery valve MUST be lose. IE THE 1/4 TURN IN PROCEEDURE!
If delivery valve is tight than no gravity feeding is going to happen.
   / Yanmar loses power, slows down & kills #142
cavitation?
Is it possible that the pump is cavitating at the lower speeds, but at the higher speeds it is not? Is it even possible for these pumps to cavitate? I wouldn't know how.
I was just thinking of how when I pump diesel into a 5 gallon can, I'll get a bunch of foam unless it's going in nice and slow (again, opposite of what's happening. But - sometimes opposites are related).
I know this sounds opposite of how cavitation usually happens, but it is the only explanation I can think of for the lack of air bubbles at heigher speeds (other than, the air bubbles are moving faster than the speed of light ;) )
Dang - I really wish I had a clue about this stuff.
   / Yanmar loses power, slows down & kills #143
Another off the wall idea (just throwing more junk out there to contemplate).
Vapor Lock.
I really don't understand exactly how that would happen in the carburated car days (Gas, of course, never heard of it on a Diesel). But, I understood it that if the fuel-line would get too warm, bubbles would form and create a bubble in the fuel-line.
California said:
I wonder if moving the filter higher would keep the pump intake flooded, while bubbles would rise clear back to the fuel tank.
This is essentially what I did when I rigged my bleeder line.
   / Yanmar loses power, slows down & kills #145
Vapor Lock.
Diesel has a much higher boiling point than gas. That's why the products that make up gas come off the top of a distillation tower at a refinery. LGP, naptha at the top, then the keros, diesel, VGO, and ATB's at the bottom.
   / Yanmar loses power, slows down & kills #146
tallyho8 said:
I need more input from other skilled deisel mechanics as to whether or not compression could leak back through a defective injector and through the injector pump.
Not likely..
   / Yanmar loses power, slows down & kills #147
rock2610D said:
Govenor!! Get a manual on these gadgets. My JD manual in very informative.
Did you know the govenor over fuels motor during startup? It can do this because counter weights are not spinning. By overfueling during startup the engine appears to run correctly until overfueling stops and govenor starts working with respect to a started engine. This is where I think you have issues. Please take a second and thrid look at govenor.
The governor kicks the fuel back at just a few hundred rpm. You can hear and see this at startup. If the governor is working properly with the new fuel line set up(load on, load off, etc), I'd rule it out. Probably the easiest thing to break in the govenor is a spring. And if this breaks you'll probably have a runaway or no speed selection. Generally the speed control lever, spring, govenor, and fuel rack are all connected.
This is a weird one but glad it's running at least. I use to have to remind myself...it was working before...what changed.
Rob
Just a note to let everyone know that I have used my Yanmar about 45 hours in the last 2 weeks with no problems at all with it rigged up as previously mentioned. I still keep wondering what the problem is that made me have to rig it like this.:confused:
   / Yanmar loses power, slows down & kills #149
Congratulations!!
   / Yanmar loses power, slows down & kills #150
That is great Tally that you can and that your tractor is usable, but boy is that nagging that it is NOT right like it should be. Where is that air coming from and why does it enter the system? I have spent a fair amount of time thinking about those question, and have not come up with anything.:confused:
Mike
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
9ft Military Cargo Trailer  Heavy-Duty, Off-Road Ready (A59225)
9ft Military Cargo...
2186 (A58376)
2186 (A58376)
2019 GENIE S-45 BOOM LIFT (A52709)
2019 GENIE S-45...
2355 (A58376)
2355 (A58376)
Deere 310L (A53317)
Deere 310L (A53317)
