Hulaballoo
- Joined
- May 19, 2023
- Messages
- 20
- Tractor
- Yanmar SA24
I bought a used Yanmar SA424 and immediately changed all fluids and filters. The tractor ran great all summer, but I was slow to address a small leak in one of the backhoe lines. I topped up the fluid in the fall, and noticed that the steering was stiff initially when cold, but would return to normal after the tractor warmed up. But in really cold weather, all of the hydraulics are stiff, bordering on non-functional.
I didn't have easy access to the yanmar branded TF500a, so went with the "equivalent" Mobilfluid 424, and initially thought that it might be too thick in cold weather. I just went out the garage to read the fine print from the nearly empty 5 gallon bucket, and when I lifted it I heard something solid slide across the bottom. I cut the seal, opened the bucket and found a good sized chunk of ice. My best guess is that the bucket got temporarily stored outside, water pooled in the lid, then leaked through the "handy" vent on top of the lid. I'm afraid that when I topped up the fluid (approximately 1 liter) I put in mostly water.
So a couple of questions...
1. What are the chances that I've damaged something?
2. Do these tractors have any ability to purge water from the hydraulic system? (I understand that I'll likely have to drain and refill, but even then there will surely be residual fluid)
3. Is a fluid change enough, or will I need to flush as well?
4. I imagine I should do both filters as well?
I appreciate your experience, as I am pretty new to tractors.
