ZD1211 or F2690
   / ZD1211 or F2690 #21
Yes. Identical to the 2690 except for electronic gauges.
   / ZD1211 or F2690 #22
Had a F2680e with 60" and 72" decks. Bought it twice. No issues with power or lack of power. If I were buying a new one today I'd buy the F2690 (if it's 4wd) with no hesitation and I live on e steep hillside where climbing power is needed. Also bought two different F3080s with 72" decks and no issues and currently have a small Z and a big Z and a F3080. They each shine in their own way. Do under trees with low hanging branches with the F and higher branches with the Z. Open field (areas) the F is hands down winner in every way.
   / ZD1211 or F2690 #23
Pete6114.....any issues with the amount of available power?? Do you a 72 inch deck or a 60 incher? I will never own a zero turn mower...too much work for me to keep it straight! My mc35 New Holland is the same concept as the F series. Back engine, front deck, steering wheel and no levers.
I took the 60 inch deck and have not had any issues at all with any lack of available power whatsoever. I keep it at 2600 RPM when cutting...not even full bore.
   / ZD1211 or F2690 #24
This is all very helpful. If I could just find one to look at and mow with it for about 5 minutes!
   / ZD1211 or F2690 #26
LOL!!
   / ZD1211 or F2690 #27
I have a zd1211 60" the 25 hp is more than suffices. I bet its fine with the 72" deck.
I mowed some knee high grass at almost full speed without bogging down
As others stated the suspended deck does scalop some in uneven ground. Its better if i pin the front axle but the rides rougher.
I wanted a f mower but didn't like the turning radius. I dont usually do z turns more of a small turn but still gets the same effect. The suspension seat gives a great ride. Much better than the neighbors grasshopper front deck. Front deck is so much better mowing around my pine trees. The option for a snow blower is awesome on the f series.
The 1211 has adjustable damper force i have mine set to lowest resistance it would be fine even lower.
   / ZD1211 or F2690 #28
The 25 hp will handle anything the deck will discharge. I don't run out of power till the discharge on the deck starts to plug off..,When that's the case the grass is too long anyway.
John Deere 6120M (A57148)
John Deere 6120M...
3PT DRAG HARROW (A52708)
3PT DRAG HARROW...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2017 Chevrolet Trax LS SUV (A55973)
2017 Chevrolet...
BARBED WIRE (A58214)
TUGGER TRAILER (A58214)
TUGGER TRAILER...
